few little ideas about cssie manifolds
been told 2wd exhaust manifolds give better gas flow if this is true can a 2wd be fitted to a 4x4 thanks
Testing the future
if bolting on a 2wd manifold to a 4x4 head, you have nowhere to mount the turbo damper which is necessary to stop the manifold vibrating and breaking studs out of the head. kits available from mike rainbird.
2wd ex. manifolds do flow better but you really have to be chasing 400bhp plus to warrant changing it. 2wd also causes more lag than 4wd.
I've been down this road myself and now I've got a Ł60 manifold sat in the garage because I ended up sticking with 4wd and saved spending extra on the damper!
wheelwizardrefurbs
21-09-2015 06:42 AM
Si B
12-09-2015 06:49 AM
