Knackered Mk6 Gearbox?
Old May 4, 2011 | 10:41 AM
mattmountney's Avatar
mattmountney
Default Knackered Mk6 Gearbox?
Hi guys, first time poster - I'm a complete mechanic noob and I need some advice on my motor or Ford are going to bend me over a barrell! For info I've got a diesel 03 Fiesta.
I clipped a curb the other day and immediately afterwards I felt a bit of vibration. I thought it was weird so I pulled over and looked at my alloy - all was fine and I hadn't mountned the curb or anything so I thought nothing of it. As I pulled away and went to go into 3rd there was a crunch and now I can't select 3rd, 4th or 5th gears. 1st, 2nd and reverse work fine but in any of the others it's like I've left the car in neutral - the gearstick actually stays in place but the engine just revs like it's not in gear. It was also making a bit of a whining noise when I crawled it home in 2nd.
I haven't driven it since but I was really hoping one of you guys could help me work out what's wrong with it...Please help!
Cheers,
Matt
Old May 4, 2011 | 10:52 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Could be a multitude of things, you not got a mechanic mate that could look at it for you? could be the gearbox itself or the linkage or cable.
Old May 4, 2011 | 02:58 PM
mattmountney
Cheers for the reply chaffe and unfortunately no, I don't have a mechanic mate.
Is the linkage and/or cable separate for each gear (I'd be surprised if it was), or at least does 3rd, 4th and 5th have it's own linkage/cable that might have gone?
Cheers,
Matt
Old May 4, 2011 | 06:44 PM
mattmountney
Any more thoughts guys, I could really do with some help...
Cheers,
Matt
Old May 5, 2011 | 10:58 AM
chaffe's Avatar
chaffe
Cheers,
Matt
TBH if i said it was/wasnt what would you be able to do to it? from what i can make out you are prehaps not great with mechanics? would you be able to fix the gearbox if it had a problem?
Old May 5, 2011 | 04:27 PM
mattmountney
No i couldn't, but if i can work out what the problem is i can look around, buy the parts i need as cheap as is possible, then pay a mechanic cash in hand for his labour to fit them.
Better than paying mechanics prices on parts as well as their labour to work out what the issue is...
Old May 5, 2011 | 06:33 PM
Drive to your nearest gearbox repair place, they will test drive your car and tell you for free if it's the gearbox, personally I'd be 99% sure it wasn't the box, more likely a issue with adjustment, the vibes may well be from a buckled alloy/wheel on the inside, or a weight fell off from the knock ?
Old May 5, 2011 | 07:13 PM
mattmountney
How would a buckled wheel stop me from putting the car in 3rd, 4th or 5th gear when stationary?
Old May 6, 2011 | 06:16 AM
chaffe's Avatar
chaffe
i think this is what he meant
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
