3dr front suspension??
Hi guys, I'm baffled!!
I had a lot of play and brake judder from the front of my 3dr, and on closer inspection, found the ball joints on the front control arms knackered, the tie rod ball joints gone, and it looked like the bushes in the front control arms had worn.
I replaced the complete arms with brand new units, standard bushes, and replaced the tie rod ends.
Test drove it today and the judder has gone, but I can still push the front wheels back towards the car body as there is a lot of play there?
When you brake, the front wheels move backwards about an inch or so!
I'm really baffled. And ideas?
They're poly bushed James and new.
Done some research and I reckon the washers for the arb to tca could be wrong or the wrong way round?
I have really dished washers on the arb and have them facing like this )-(
The tca bush being the - and the washers facing outwards?? This wa how they were fitted so I put them back that way?
I thought the washers should be flat myself?
Yep, been through the whole suspension set up, checking bolts etc. top mounts are tight, anti roll bar bolts are tight, brackets are tight and all ball joints etc tight.
If you grab the tca and push it back, it goes back and the bush in the tca flexes allowing it to. That's why I thought it could be the washers?
I'm fuckin baffled!
That's what I thought.! So if I fitted polyflex tomorrow, do the washers need to be () or )( ?
Also, what's the best way to get the standard bushes out?
Thanks so far guys!
Just looking at the Workshop manual and as you describe seems correct.
The power flex washers go )( as well.
The rubber bushes can be tapped out with a screw driver from the edge, as there is a metal edge band on them
Washers go this way whether it's standard bushes or uprated ones of some type ) (
Also standard bushes allow quite a bit of movement as their name would suggest " compliance bushes "
This is not a fault as it's designed this way , I did find it funny aswell when I was MOT testing Sierras many years ago
John
