Focus engine question
Old Jan 12, 2011 | 11:44 PM
am4nf's Avatar
am4nf
Default Focus engine question
My gf's dad has a 52 plate mk1 1.6 zetec focus and its got really really bad piston slap by the sound of it, garage said its either the crankshaft or a piston, but today he put it back in for them to get the head off for a look and they have said the engines goosed.
So my questions are, are the mounts for the 1.8 or 2.0 the same as the 1.6? & are the mk2 engines the same as the mk1's? if not will they fit the mounts anyways?
Are there any differences in the likes of the ghia's or lx?
Basically would either engine drop straight in, the 1.8 & 2.0 seem much cheaper than the 1.6 engine on ebay.... so I was thinking why not get a bigger engine while hes at it
Any help would be great
Old Jan 13, 2011 | 12:09 AM
Escow-Van's Avatar
Escow-Van
1.8 and 2.0 are the same as each other - but not the 1.6, 1.6 and 1.4 are Zetec SE engines, whereas the 1.8 and 2.0 are Zetec E.
Mk2's have Duratec engines and are different all together.
Trim level won't effect the engine as such, though you may get an air con pump on some, not others.
Unfortunately I think a 1.6 is the best option. I'm surprised the 1.6 is more expensive tbh, I'd have thought it was much more common.
Old Jan 13, 2011 | 12:13 AM
am4nf's Avatar
am4nf
A lot more 1.8's than anything else tbh
So are the mounts different on the 1.8 to the 1.6?
Old Jan 13, 2011 | 01:15 AM
phil_focus's Avatar
phil_focus
there are LOADS of things different on the 1.8/2l than he 1.4/1.6.
intake and exhausts are on different sides for a start. sensors and management are different so will need engine loom and ecu, then you'll have to sort the immobiliser out and possibly keys.
not worth it unless the car is a good base and you want to drop a big bhp motor in.
incidentally any 1.6 zetec se will do, early or late gen (aluminium cam cover and plastic), they'll swap no problem.
Old Jan 13, 2011 | 08:45 AM
Be careful with the 1.6, as there is one engine that has inlet front exhaust rear.
Old Jan 13, 2011 | 12:37 PM
martysmartie's Avatar
martysmartie
The 1600 Sigma (Zetec-SE) you have and the 1.8-2L are completely different engines the only resemblance being the name, so to answer your question if you want a straight swap you need another identical engine, this also came in two phases (Mentioned) with subtle differences (Early models had a metal cam cover with "Zetec-S" the later had a plastic cam cover with "Zetec-SE" printed on it, this is how to easy tell the two apart, but both would fit.
Don't be fooled into getting this engine rebuilt, the bottom end is a "Throw Away" component on these engines and thus Ford do not supply tolerances.
All have a plastic inlet manifold at the front, if your looking at an 1600 otherwise then it isn't an SE.
Incidentally the 1.8-L (Zetec-E) has opposing manifolds so this is just one major amongst many differences between these engines.
As to trim levels, mechanically no, trim wise lots of differences. (The Zetec has sports suspension)
Martin
Old Jan 13, 2011 | 01:47 PM
phil_focus's Avatar
phil_focus
the 1.6 silvertop with exhaust a the front is an early zetec e. all zetec se's are the other way round.
just thought i'd clarify that for the OP
Old Jan 13, 2011 | 02:19 PM
am4nf's Avatar
am4nf
cheers for the info guys, so phil that means I need to match the engine exactly to weither its a silver or black top?
Old Jan 13, 2011 | 02:23 PM
phil_focus's Avatar
phil_focus
no, just so long as its a 1.6 zetec se engine you will be fine. he early zetec se had a silver aluminium cam cover with zetec s on it but its essentially (only minor differences) the same as the black top zetec se.
i'll try and find some pics to clarify, make sure we're on the same page. now wheres google
Old Jan 13, 2011 | 02:31 PM
phil_focus's Avatar
phil_focus
here we go.
late generation 1.6 zetec se with black plastinc cam cover...incidentally pictured in a focus
http://www.greylizard.net/images/for...fordfocus8.jpg
early generation 1.6 zetec se with silver aluminium cam cover, says "zetec s" somewhere (might be on the engine cover - not pictured - as oposed to cam cover).
http://is01.thegumtree.com/image/big/36720933.jpg
both the above engines are interchangable. one of the guys on here has swaped them in his focus when his original engine died so its been done before.
early generation (silver top) zetec e in 1.6l capacity. also did 1.8 and 2l. late generation zetec e were only 1.8 and 2l with black plastic cam covers. note exhaust and inlet completely different and on opposite sides of engine.
http://media.turbosport.co.uk/2005/2...0502211942.gif
Old Jan 13, 2011 | 03:13 PM
am4nf's Avatar
am4nf
So it wont matter which 1.6 he gets then?
Old Jan 13, 2011 | 04:30 PM
martysmartie
So long as it's a 1600 Zetec-SE then no!
Martin
Old Jan 13, 2011 | 05:03 PM
phil_focus's Avatar
phil_focus
^^^ what marty said.
Old Jan 13, 2011 | 09:55 PM
am4nf's Avatar
am4nf
Ok cheers
Old Jan 13, 2011 | 10:02 PM
phil_focus's Avatar
phil_focus
not a prob
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
