Focus cam belt
Old Oct 14, 2010 | 06:22 PM
tunners58's Avatar
tunners58
Default Focus cam belt
anyone ever changed focus cam belt.
Old Oct 14, 2010 | 06:41 PM
Done a fair few yes, what's the problem ?
Old Oct 16, 2010 | 08:11 PM
tunners58's Avatar
tunners58
Default Focus came belt change
Do I need any special tools to do this job.
Old Oct 16, 2010 | 08:48 PM
rs turbo j's Avatar
rs turbo j
virgin
It helps to have the special tools mate. Im mechanic for ford iv had to do loads old new 1.4 to 2.0 liter diesel and petrol.
Old Oct 16, 2010 | 08:59 PM
martysmartie's Avatar
martysmartie
If you buy a kit then you usually get the locking pin which you need, most important thing is to be meticulous about the timing as these have no timing scribes.
Martin
Old Oct 17, 2010 | 04:52 PM
Dead easy to do, as said get a proper kit, this will have the correct length TDC pin in the kit.
Take the plugs out when doing it, that way when rotating the engine by hand you have actually hear the ping/knock as the crank web contacts the pin, the flat bar is used to lock the cams, make sure you do undo the cam bolts, just 1/2 turn is plenty so when belt is tensioned they are free to rotate slightly.
Prior to fitting the tdc pin line up on tdc by the cam slots(these are offset so bar only goes in one way), then rotate counter clockwise the crank about 30 degrees, insert pin after removing the 10mm bolt at base of block, make sure it is screwed in fully, then when you rotate the crank CLOCKWISE you will hear and feel it contact the pin.
Just be aware there are 2 different types of rocker cover gaskets, buy both and take back the incorrect one for refund, the last one i bought from ford for a 2L ghia mk1 focy I used the reg number, and it was still wrong!!, luckily I decided to get the "wrong" one at the same time which was correct!!
Old Oct 17, 2010 | 05:24 PM
RichieST's Avatar
RichieST
I thought this was a massive no no, as the cam pulley is press fitted onto the cam instead of using a woodruff key?
Old Oct 17, 2010 | 06:58 PM
zippyobrien's Avatar
zippyobrien
Nah there just held on by the tension of the volt. Same as crank bolt. Make sure u use new crank bolt. And don't torque it up against the timing pin. Lock the crank through the starter gap.
Lee
Old Oct 17, 2010 | 07:53 PM
I've always torqued via the cam slot, the torque setting isn't a lot, I've never replaced the bolts either, never seen a problem.
dombanks
Sep 21, 2015 08:38 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
grishenko45
Sep 9, 2015 12:58 PM
rog
Sep 4, 2015 07:24 AM
