advice on removing a snapped off temp sensor
Old Apr 26, 2010 | 02:17 PM
Slackbladder's Avatar
Slackbladder
Default advice on removing a snapped off temp sensor
ok removed and fitted a new temp sensor on the rs turbo today.. checked sensor before fitting and temp gauge moved so was well happy...
old one came out no trouble... cant say same bout new one going in... as getting to tight... the end has snapped off leaving a piece stuck in block...luckly..no leak..but any advice on removing as dont wanna shag block etc.. cant beleive the luck..thinking sensor may have been brittle or something...
Old Apr 26, 2010 | 04:26 PM
The sensor body is made of brass normally, so easy enough to drill, use a cobalt bit if you can with a bit of diesel fuel for cutting lube, drill out enough so you can get a decent extractor in there, inside the sensor is only a thermistor so will not cause any problems, check you don't drill too deep though, ie all the way through!!
manuel boeckx
13
Oct 3, 2015 02:29 PM
Derek Burleigh
Sep 16, 2015 06:27 PM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
