mk4 escort, steering wheel removal
Old Apr 13, 2010 | 08:03 PM
mill5y's Avatar
mill5y
Default mk4 escort, steering wheel removal
Hey guys, I have a new ignition lock/barrel to fit and wanted to know about the process is the steering wheel just the 1 nut then should pull off?? I gave it a pull but didnt move what so ever is it just a case of grow some muscles and pull it or is there a technique to it? cheers again
Old Apr 13, 2010 | 08:08 PM
martin24uk's Avatar
martin24uk
the ones ive done have just pulled, try hitting it with a rubber mallet on the
boss, or just yank the thing with all your might !!!!!
Old Apr 13, 2010 | 08:12 PM
neil andeRSon's Avatar
neil andeRSon
leave the nut on a few thread's or you'll nock yer teeth out!!
just a case of pulling it. as for the barrel turn the ket to accesory setting 1 there's a hole on the underside of the barrel there's a little metal locking pin push that up and the barrel should just pull out..
Old Apr 13, 2010 | 08:14 PM
turbobill's Avatar
turbobill
once youve undone the nut, put the key in and turn round once to take the steering lock of,when ive done mine ive pushed on the top of the wheel and it tends to loosen it up, then you can pull it off
Old Apr 13, 2010 | 08:20 PM
mill5y's Avatar
mill5y
I'l try agin tomorrow maybe have some weetabix... On a maybe more serious note I have kind of misplaced my ign key, wasnt the best of moves but did kind of hope that I could change it with out is this possible?
Old Apr 13, 2010 | 08:37 PM
neil andeRSon
not sure mate. the ket need's to be in position 1 before you can push the metal tab in. i suppose you could ram a screwdriver down the old barrel an try turning it??
Old Apr 14, 2010 | 12:35 AM
jon@work's Avatar
jon@work
Undo the 4 M8 nuts that support the outer steering column - 2 near the top, 2 about 8-10 inches further down. With these removed, the outer column, to which the steering lock is mounted, can slide towards you by about an inch (effectively, the making the inner column shorter) and you can then tilt the steering wheel, top towards you, to remove it from the lock teeth.
Old Apr 14, 2010 | 08:14 PM
Toe Knee's Avatar
Toe Knee
silly question but were u trying to remove the barrel in the first place by taking the wheel off?! cos u didnt have too lol. Just do what jon said, will be a bit of a pig getting the lock out without the key thou!! I have got a spare lock and barrel and i think the whole lock/barrel assembly somewhere should u need them!
Old Apr 14, 2010 | 08:25 PM
mill5y's Avatar
mill5y
I was changing the lock yea, I got it off prized the metal tab up with a small screwdriver and pulled on steering wheel as was doing it was a bit of a bi**h but done it now cheers for the info guys
Old Jul 31, 2017 | 06:48 PM
WAC's Avatar
WAC
Hi Guys, new to the forum but need to tap in on your vast knowledge. Does anyone have any pictures of how the steering column shaft bearings are assembled on a 1998 MK 4 escort. I have both lower plastic bushes and the upper white plastic bush and metal sleeve just need to know how it all goes together as it was in pieces when I got the car.
Many thanks
Old Jul 31, 2017 | 10:05 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
JoeyBoyden
Jan 4, 2024 02:36 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
RockinRein
Aug 19, 2015 07:08 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
fatboy billy
Aug 3, 2015 08:34 AM
