boost on a 2wd cossie
Old Apr 12, 2010 | 11:46 PM
paulgsi's Avatar
paulgsi
Default boost on a 2wd cossie
just hooked up the boost guage on a 2wd cossie sierra i got a few weeks ago , im new to the ford scene and just wondering what its safe to be boosting at , it currently goes as far as 1.5 bar of boost dont think there ia anything done to the engine only a gp a headgasket , wat is standard boost on this car , thanks lads
Old Apr 13, 2010 | 11:25 AM
Std is around 0.7/0.8, so I would open the ecu and see if there is a different chip inside, if someone has simply upped the boost by body means it could kill your engine, by not having the fuelling to go with it.
If it's new to you, best thing is a mega service, everything inc new fuel filter, fuel pump rewire, fan rewire, change cts and ats, then get it set up/adjusted on the rollers for a fuelling check.
Old Apr 13, 2010 | 05:29 PM
martysmartie's Avatar
martysmartie
Must be chipped, if standard they hit a serious boost cut after 0.7/0.8 BAR, to tell open ECU and look at chip almost certainly will be stage 3 at that boost. Also look at the colour of the injectors will most likely be green (803's) or Blues (400's)
Martin
Old Apr 13, 2010 | 05:34 PM
Toe Knee's Avatar
Toe Knee
as said check the injectors and chip which will at least tell u what power it may be running, is the turbo a t3 or t34?!! Also silly question but didnt the previous owner tell u what spec it was before u bought it?! or any paperwork?! Either way deff worth getting it somewhere for a check over just to be safe!
Old Apr 13, 2010 | 10:01 PM
paulgsi's Avatar
paulgsi
the ludar said there was a lot money spent on it a few years ago but cant find the paperwork , he said he remembers it being 270 bhp , ya iv it fulkly serviced already , and theres green injectors on it and group a turbo is wat he called the turbo , i dont know much about fords wats ats and cts and why should i change them thanks for the help lads should i just fit a fuel air ratio guage just to see
Old Apr 13, 2010 | 10:17 PM
martysmartie
Just like I thought thats a stage 3 conversion not 1, turbo is certainly a T34 not a "Group A" what his saying to see check to what markings it has on it.
CTS= Coolant Temperature Sensor this is a thermister that supplies ECU with coolant temperature info hence the name.
ACT= Same sensor in diffrent housing but this measures air temperature instead and is screwed into plenum.
They can go out calibration but never had a problem with mine so never touched.
Martin
Old Apr 13, 2010 | 10:39 PM
paulgsi's Avatar
paulgsi
oh right ya , well when i got the car it was driving spot on but the boost guage was disconnected , so hooked it up the other day and was very surprised to see it boosting 1,4 bar , and taut maybe i should stop driving it incase its far too much for wat the car is capable of , ill check and see wat turbo i have , and let ye know , is it stage 3 then yea ?
Old Apr 14, 2010 | 12:23 PM
martysmartie
Yes for the boost it's running along with green injectors and probably has a T34 turbo as well.
Martin
Old Apr 14, 2010 | 12:37 PM
mark needs help's Avatar
mark needs help
cosworth nutter
It al sounds fine 2 me m8. Take 1 ov the plugs off ur injectors n check the colour. If there green its stage 3. N u can turn the boost up more if u want. Up to 2 bar. Like 28psi. As long as u ent misfirin at peak boost in 3rd its fine.
Do the boost test. Floor it in 3rd and alpy the brakes. No lnger than 5 secs tho!!! 2 increase boost wind the act rod in slitly n repet the test til ur hapy
Old Apr 14, 2010 | 12:56 PM
paulgsi's Avatar
paulgsi
ok thanks for clearing that up so lads ill continue blasting around in it so cheers
also just wondering if i put a larger fmic on it would i get much gains over the standard one , cause the standard one looks efficient
Old Apr 14, 2010 | 01:03 PM
martysmartie
NO YOU CAN'T JUST TURN THE BOOST UP!!, well unless you want to destroy your engine! You need to run the correct amount of boost it's mapped for.
Martin
Old Apr 14, 2010 | 01:19 PM
martysmartie
Unless the standard cooler is having trouble cooling the charged air you will gain no benefit by fitting a RS500 style cooler.
Martin
JK12
33
Apr 26, 2021 12:09 PM
markk
Sep 9, 2015 08:11 AM
jc1989rs
Sep 5, 2015 08:09 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
