ISCV
Old Jan 16, 2010 | 08:31 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Default ISCV
i took my idle speed contol valve out and cleaned out all the gunk with wd40 and looked all spik and span. Still got slight up and down revs sometime reving to 1.5k. Any ideas. Cheers
Old Jan 16, 2010 | 10:41 AM
I would check CO first, could be running lean.
Old Jan 16, 2010 | 07:28 PM
kosienutter
how do/where do i look for this mate.?
Old Jan 16, 2010 | 08:15 PM
martysmartie's Avatar
martysmartie
You need to find out what the CO level should be for your chip measured as a percentage assuming it's not standard if so I think it's 2.5%, you then need a exhaust gas analyzer, get the car upto running temp, make sure cooling fans are not on at the time of checking. The level is adjusted by the screw on the ECU.
Martin
Old Jan 16, 2010 | 09:14 PM
kosienutter
ok thanks ever so. Will have a gander tomorrow. cheeRS
Old Jan 16, 2010 | 09:16 PM
saph_Al's Avatar
saph_Al
u need to become friends with an mot tester and borrow his gas analyzer and make sure ur co is right then id be lookin for a poss air leak
Old Jan 16, 2010 | 09:29 PM
kosienutter
air leak. Ah ok. Well does this help. I took the hose of the top of my grp a dump valve and the revs went up and stayed there steady at just over 1k. And when i connected it again the iscv did its adjusment noise and carried on doing its usually thing. Thanks for the help guys. Can i run the car, once warmed up with the iscv loom connector disconnected with oit doing damage as when i disconect it the engine idles perfectly again once warmed up cause when cold the engine nearly stalls lol.
Old Jan 16, 2010 | 09:50 PM
martysmartie
Yes the only time ISCV is when cold and if any heavy electrical load is applied, to allow more air in so if not connected it won't start. Once up to temp and unplugged it won't make any difference as it's not being used. It will do no damage at all.
Martin
Old Jan 16, 2010 | 09:59 PM
kosienutter
so i can make my own switch sort of thing connected to one of the loom wires and put a break in it via a simple 2 pined switch. Happy days.
Old Jan 17, 2010 | 10:16 AM
You could, but you could also fix your leaky DV first, that fact it speeded noticebaly shows it is leaking, is it a diaphragm type ?.
If you just set the idle a bit higher say 1000rpm and just hold for a few seconds when cold it will still idle lumpily.
If the fuelling is ok it can still start and idle from cold with no iscv, loads do, esp on differrent mappable ecu's.
Old Jan 17, 2010 | 03:59 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
check tps calibration
DixieTheKid
11
Jun 6, 2020 11:20 AM
RSmark84
Sep 13, 2015 01:29 PM
cozzy jeff
Sep 12, 2015 04:32 PM
muffster
13
Sep 3, 2015 09:40 PM
Cosnada
Aug 27, 2015 09:15 AM
