cam bits?? do i need
Old Jan 17, 2010 | 03:29 PM
moggyfrst's Avatar
moggyfrst
Default cam bits?? do i need
hi all, rite am putin a kent 34 in my frst do i realy need to get a new cam thrust plate an cam nut or should the old's one be fine, coz iv been told that ford dont sell the plate any more, if this is true were can i get one.
cheers
Old Jan 17, 2010 | 05:53 PM
Unless your cam thrust plate is worn to buggery ie grooved and chewed up, it will be fine.
Do you mean cam bolt in the centre of the pulley ?, if so will be ok just don't overtighten and use a torque wrench.
If you are reffering to a nut, if it's a nylock nut, with plastic/nylon insert just use a new one, they're only pennies.
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Nov 3, 2015 04:08 PM
rog
Sep 4, 2015 07:24 AM
Ben26
Sep 3, 2015 07:55 PM
Sep 3, 2015 10:49 AM
