ka valve prob,head removed
Old Jan 15, 2010 | 07:42 PM
bluey's Avatar
bluey
Default ka valve prob,head removed
hi all,just joined (after this post i will go and introduce my self )
ive got a 1999 ford ka with head gasket problems.
ive just got it and the owner before me said it has head gasket problems.
it smokes badly out of the coolant tank and exhaust,drinks water.
i did a compression test and had no compression on number 3 and very low on number 2. ive removed the head and the gasket was gone in between the middle ones. i thought nice easy fix.but then looked at the valves and
not nice.
could someone give me some advice please.i take it that the valve might be bent
thanks
jay
Old Jan 15, 2010 | 07:45 PM
babscossie's Avatar
babscossie
Cheapest option is a second hand engine mate. Thats got bloody hot to drop a valve seat. God knows what the rings etc will be like.
Old Jan 15, 2010 | 07:50 PM
bluey's Avatar
bluey
thanks for the quick reply, would it be cheaper to buy a new engine,finding it hard looking for a good cheap head 2nd hand.
thanks jay
Old Jan 15, 2010 | 07:57 PM
bluey's Avatar
bluey
ive got a head gasket set and has the valve seals in it. would it be worth fitting them to that head. or just get a 2nd hand head.
thanks
Old Jan 15, 2010 | 08:05 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
that engine got dam hot to drop a seat imo.
i would not risk fitting a head i would fit an engine can be done in a few hours any ways no point fitting that head back on wont be much if any better and to evon think about fitting a head in that state WELL ................
Old Jan 16, 2010 | 10:56 AM
The head as said has got seriously hot to do this, I have seen some x flow heads so bad you could push the guides out with your finger, still bloody hard though!!
I wouldn't bother with the whole engine, I would just get another head as will be cheaper than repairing yours I would imagine, if you can get a good engine cheap enough though you could just replace the lot.
Old Jan 16, 2010 | 11:08 AM
bluey's Avatar
bluey
thanks for all the info.im managed to get a good 2nd hand head. hope the bottom of the engine is ok.
thanks
Old Jan 16, 2010 | 11:13 AM
RONNIE AMIS's Avatar
RONNIE AMIS
same thing happened with my mum's KA head, as long as the bores and pistons are ok you can replace the head.
i bought a re con head for my mum's and fitted it and all was ok
RUBY123
Oct 22, 2023 12:04 PM
Bailes1992
Sep 3, 2015 02:17 PM
YODI
Aug 30, 2015 01:12 PM
Aug 29, 2015 08:16 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
