Diesel engine swap ?
Old Dec 21, 2009 | 09:11 PM
fezzyvan's Avatar
fezzyvan
Default Diesel engine swap ?
Hello all,
I'm new to forums but would like some help please.
Will a engine from a 1999 escort van fit into my 1997 fiesta van as my cambelt has snapped both are 1.8d ?
Also in my escort van the heaters blow only warm air when put on full but if turned off for a few mins and then put on full it is hot for a few seconds, would this be the heater control valve if the 99 had on or the thermostat.
Cheers !
Old Dec 22, 2009 | 05:57 PM
Yes the engines if the same will swap over, so long as both non turbo.
The heater could be partially blocked, or more likely a dud stat, so if swapping engines just put a new one in anyway, it would be quicker swappings heads than engines, and fitting 2 new belts at same time, most ignore the pump belt, until it snaps and jams up in the cam belt next to it!!
You may want to check the valve clearances at the same time, easy to do on bench then do swappsies but any you need are only around Ł3 each anyway.
I don't know for certain if they have one of the dodgy water valves like some other fords, but suspect not, just follow the pipes through the bulkhead to see if there is avalve anywhere though I doubt it on this engine.
Old Dec 22, 2009 | 06:03 PM
fezzyvan's Avatar
fezzyvan
Thank you so much for the reply, it has really cleared everything up for me.
Cheers.
JoeyBoyden
Jan 4, 2024 02:36 PM
Vincereese
Sep 5, 2015 10:46 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
taylora1409
Aug 12, 2015 12:06 PM
vdubo7
Aug 2, 2015 08:17 PM
