capri electronic ignition ?
Old May 17, 2009 | 06:10 PM
hawkmoon269's Avatar
hawkmoon269
Default capri electronic ignition ?
can you help guys ? i have 2.0 ltr capri on carbs, can someone tell me how to covert/transplant a 2.8/2.9 into my capri,? can manage engine swap but when it comes to changing carbs to electronic ignition i'm stumped!! any help gratefully accepted, thanks.
Old May 17, 2009 | 06:40 PM
Electronic ignition is the same whether you have carbs or not, just use the same ignition stuff off a V6 sierra/capri etc, that's electronic.
Old May 17, 2009 | 07:10 PM
hawkmoon269
Thanks 4 replying tabetha, so from what you said i'll need amp module from doner car, anything else ? wiring loom etc ?
Old May 17, 2009 | 08:04 PM
andycos's Avatar
andycos
Try and get the whole wiring loom from a 2.8i with amp and and fuel pump relay e.t.c.
Also fuel tank as you will have to fit a fuel return pipe as well.
If you have access to a 2.8i being stripped,just try and get everything attached to the wiring loom.
Shouldn't be to hard then !
Old May 17, 2009 | 08:21 PM
costina's Avatar
costina
Live long and prosper!!
Talk to stucapri2.9iTT he will tell you what u need
you will be better off fitting a 2.9efi from a granada
Paul
Old May 18, 2009 | 05:59 AM
Better off fitting a YB!!
cossie brad
Sep 29, 2015 02:38 PM
jonnyenglish
Sep 21, 2015 07:31 AM
beller
Sep 21, 2015 04:13 AM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
