Clutch Dilemma Mk4 Fiesta Zetec Quick Reply Needed!!
Hi all, my clutch went on my mk 4 fiesta zetec yesterday, after a few weeks slipping, now i have th option to purchase a 2pc clutch kit for £49 or a 3pc, with concentric sleeve for £118, fitting is not the worry, but i dont really have the money to splash out for the concentric sleeve, will i be fine just replacinmg the two clutch plates? or is it a necessity to get the sleeve, cheers, Max
PS am in bristol if anyone knows a place that will sell these kits cheaper, seems a good price tohugh.
Im assuming so, the guy just said the 3pc was for the concentric sleeve, i dont really know much about clutches so im a bit baffled, dont want to buy the 3pc really unless its absolutly necessary
i dunno, on that 1 , i thought all ford gearboxes all fitted the same like cvh zetec etc, if it was slipped i would say the 2 piece would be fine, but i dont know what its ment by the concentric
http://cgi.ebay.co.uk/FORD-FIESTA-KA...3%3A1|294%3A50
Im assuming thats the 3 piece, with the slave cylinder
YES I KNOW I CANT SPELL
its a hydrolick relice bairing and they are common for leaking and contaminating the clutch hence they slip. ive changed a few clutches with this type of relice bairing and some ive checked the condition of the bairing and thort it was fine yet a few mounths down the line they have come back leaking.
so now i dont think twice about changing the bairing/hydrolick cilinder as the box has to come out to change it. and most of the time it will contaminate the clutch any how so you will end up fitting a new clutch agan
So its a definate purchase of the 3 piece then? how do you know what condition the bearing is in i,e thigns to look for, could i buy the 2 piece and get a release bearing from a scrapper?
lol its realy not worth it mate on the clutches ive changed the bairing seems in near perfict condition so i thort why change it if its not broke? but then a few mounths down the line the car is back with a leaking releace bairing witch has killed the new clutch i have fitted, it seems as soon as you desterb them ie take the box out to change the clutch. its only a matter of time befor they start to leak. same gos for a second had one its just not worth the rick of killing a new clutch IMHO. it will end up costin g you mose in the long run
By the way, i know this probably sounds absolutly stupid to the mechanical- wise, but, does the release bearing have a seal to stop it leaking then? and could i wrap some PTFE tape around it o give it a tight fit?
JoeyBoyden
04-01-2024 02:36 PM
matman
09-09-2015 05:45 PM
