Cossie engine leaking oil
Old May 2, 2009 | 04:33 PM
cossieprob's Avatar
cossieprob
550+ LUV IT!!!!!!!!!!!!!!
Default Cossie engine leaking oil
Can anybody help please, got a small leak thats coming from the front on the engine behind the cam pully's and running down the block.Iv changed the half moons and the cam seals but still leaking it seem's to be coming from the metal bolt below the cam seals and the cam bearings seem abit nosiey,if the cam bearings wear do they leak oil ?? its putting oil on the belt and chucking it all over the engine bay. Can any one help?
Old May 2, 2009 | 07:36 PM
Toe Knee's Avatar
Toe Knee
have u tried taking the bolt out and having a look?! shouldnt be leaking from there as it isnt tapped deep enough unless someone has helicoiled it and gone to deep or something?!
PS did u put sealant on both ends of the cam seal?! if not it'll still leak out even with new half moons!!
Old May 2, 2009 | 08:12 PM
Did you put sealant under the cam caps, otherwise they will leak from the join between cap and head and run down looking like it's the cam seals.
Did you use Viton seals as they are way better, but new ones should still last a while.
Old May 5, 2009 | 09:58 AM
Char1ie's Avatar
Char1ie
Agree with this. Mine was oozing oil out from behind the cam pulleys and all over the block. Did the cam gasket and half moons but when I lifted the front cam caps there was a lot of oil underneath so I added liquid gasket under them. It seems a lot better now.
Charlie
Old May 5, 2009 | 01:25 PM
cossieprob's Avatar
cossieprob
Cheers lads, what do u mean by lifting the front cam caps? I didn't do the round cams seals behind the pulley's i got a local ford rally garage to do them.ITs not leaking from the seals itself but from the round metal surround that the seals are put in to, and running down on to the bolt,is this surround sealed by the cam bearings from the inside, as i said before the bearings sound a little louder.The cars going to msd this friday for a live map check but its a long drive from south wales with a little oil leak , my be get it look at then.CheeRS for your info. Rich
Old May 5, 2009 | 01:35 PM
costina's Avatar
costina
Live long and prosper!!
Take cam cover off and remove the 2 front cap caps held by either 4 m6 nuts or 4 m6 cap heads if 4x4 head
Where these meet the head clean and put some sealer there and refit cam caps
also put a bit either end of the half moon seals refit cover
Job done
Paul
Old May 5, 2009 | 01:40 PM
cossieprob's Avatar
cossieprob
Thanks paul il do that.
Old May 5, 2009 | 01:45 PM
costina's Avatar
costina
Make sure you tighten to correct torque 10 nm for caps and same for cam cover
Paul
Old May 5, 2009 | 04:15 PM
cossieprob's Avatar
cossieprob
Paul
I will m8 cheeRS
Old May 5, 2009 | 05:42 PM
Don't be tempted to overtighten, it doesn't stop leaks but can strip threads.
Old May 6, 2009 | 05:21 PM
cossieprob's Avatar
cossieprob
Iv done the cam caps today , and there was oil under them so sealed them and run the engine till the fans came on and the leak has stopped. Before it was leaking on tick over,SO A BIG THANKS TO YOU THAT GAVE ME THE INFO, ON WHAT TO DO.CheeRS Rich
Old May 6, 2009 | 06:15 PM
costina's Avatar
costina
Good job now ready for Stu and the live map
Before then double check everything connectors,oil,water everything it will save u time and money as theres nothing worse than having a car in you have to fix small issues first
Paul
Old May 7, 2009 | 09:59 AM
cossieprob's Avatar
cossieprob
Paul
Spent a good couple of hours the other day checking the car , making sure its all good . The 3door,s already live mapped at well over 500bhp , just going up for a good once over and a new actuator.
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
mattman1234
24
Aug 1, 2015 11:46 AM
