Leaky sump
Old Apr 9, 2009 | 01:19 PM
JoshXR2's Avatar
JoshXR2
Default Leaky sump
Changed the sump gasket on my rst tightened all bolts according to the manual and now have oil exiting under pressure but only after the engine has stopped cranking. Any ideas as to what this could be?
Old Apr 9, 2009 | 04:04 PM
cosrep's Avatar
cosrep
Is it at the timing belt end or the gearbox end?
Its usually the gearbox end that leaks after a sump gasket change, its a stupid design and some people will go as far as to remove the gearbox to ensure the gasket doesn't kink or move when fitting.
Old Apr 9, 2009 | 06:57 PM
JoshXR2's Avatar
JoshXR2
The leak is from dead central in the sump only on the driveshaft side.
Old Apr 9, 2009 | 08:02 PM
lurch1977's Avatar
lurch1977
Although you tightened it as recommended I would also say that when fitting a seam of instant gasket just to make sure you get a seal. When I first did it took me 4 attempts.
Old Apr 10, 2009 | 05:55 AM
JesseT's Avatar
JesseT
Best mod is to improve the crankcase breathing.
Old Apr 10, 2009 | 05:14 PM
cossiedan1983's Avatar
cossiedan1983
the sump gasket can be a bit tricky on these the best thing is a bit of sealer and let it dry 1st so none goes into the oil which can block oil galleries and the pick up, but also try group a breather system the standard breathers as much use as a kick in the bollocks
Old Apr 11, 2009 | 03:22 PM
JoshXR2's Avatar
JoshXR2
When you guys say about these breather systems what do you mean as i had put one on but i didn't know if that was the cause. I'll post some pics of it.
Old Apr 11, 2009 | 06:19 PM
JesseT's Avatar
JesseT
When the pressure inside the block becomes high, the sump gasket fails easily and a gasket that wouldn't leak normally starts to leak. A good modified breather system let's the crankcase gases out with much less restriction.
Iain Mac
Sep 30, 2015 09:39 PM
youngben
Sep 27, 2015 09:37 PM
little bram
Sep 21, 2015 02:50 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
