Fiesta ST Tracking
Old Feb 18, 2009 | 05:10 PM
daz-cos's Avatar
daz-cos
Default Fiesta ST Tracking
Girlfriend got her car tracked today, after getting new tyres, after other ones got scrubbed out due to tracking, car still seems to pull to left slightly, just wondered if anyone know what the correct settings should be, got this print out just doesn't look right to me.
Cheers for your help in advance. daz
Old Feb 18, 2009 | 05:16 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Unsure of the settings mate and I'm no mechanic so couldn't answer for definite in regards to the printout above.
What I do know and what I have experienced on my own car is the Fiesta ST "characteristic" is to pull slightly to the left with the fall of the road as with most other cars.
Also if you have maintained the P-Zero's on the car from the factory and replaced like for like then the Pirelli's are well known for tramlining.
Tim
Old Feb 18, 2009 | 05:36 PM
daz-cos's Avatar
daz-cos
i havent driven it yet only going on what she has sed about it pulling thoug it did pull b4. just replaced the pirellies 4 toyos so al c how it is now with regards 2 tramlinning
cheers
Old Feb 18, 2009 | 05:47 PM
daz-cos's Avatar
daz-cos
also, how do ur tryes wear, hers were bald on inside but fine on the outside. i know sum cars do wear like this due to camber just wondered if fiestas do
Old Feb 18, 2009 | 05:51 PM
Rick Astley
My tyres don't suffer from any uneven wear that is noticeable to my eye
Old Feb 18, 2009 | 06:26 PM
daz-cos's Avatar
daz-cos
yea i dident notice until i took the wheels of. al just have 2 wait and c .
cheers
Old Feb 18, 2009 | 08:05 PM
siward's Avatar
siward
That print out looks spot on to me, Toe, camber and caster is bang on
Si
Old Feb 18, 2009 | 08:54 PM
PAUL JA's Avatar
PAUL JA
Front toe in should be 1.1mm total +/-1.2mm
Rear toe in should be 3.6mm total +/-4.8mm
Hell of a tolerance there !!!!
Rear toe is all on one side (not correct - and not adjustable) causing the thrust angle - that may well be why it pulls one way
Old Feb 18, 2009 | 10:37 PM
James998's Avatar
James998
Fiesta ST's are notorious for wearing the edges of the front tyres out, not uncommon for them to come in for their first service and the inner edges be completely bald.
Old Feb 19, 2009 | 07:35 PM
daz-cos's Avatar
daz-cos
so if my rear toe is wrong and not adjustable how do u put it right?
cheers
Old Feb 19, 2009 | 08:15 PM
PAUL JA's Avatar
PAUL JA
cheers
Sorry can't really answer that. Assuming all is straight i.e. no accident damage. Depends on how the rear stubs are fixed, if they bolt on then shims maybe an answer. Better speak to an expert in alignment.
Old Feb 20, 2009 | 01:17 PM
JonathanJ's Avatar
JonathanJ
Looking at the figures above the left rear wheel seems to have 3.1mm toe in and the right rear 0.3m toe out , would think this is causing a slight bit of the issue , but as mentioned above and from personal experience it will follow the camber to the left as most fords do . If you want to improve the rear tracking the only way to do it is move the mounts on the chassis for the rear beam to achieve a better balance
Old Feb 20, 2009 | 06:45 PM
PAUL JA's Avatar
PAUL JA
Taken my sons ST150 in today to have the alignment checked and adjusted, Guess what near side rear was 3.1mm toe in (wonder if they are all the same). Had to use a shim behind the hub to adjust, couldn't get it a perfect match to the off side but did set rear to 2.4mm total toe in and reduce the thrust angle vitually 0.
I went to Carnetix in Melton Mobrey (contact Glen / Becky - they have a website)
ossie cossie
57
Nov 21, 2022 10:05 AM
89barto89
Oct 4, 2015 06:59 PM
Mark_
40
Oct 2, 2015 04:40 PM
muzzman1
Sep 30, 2015 08:59 PM
Andypandy260
Sep 23, 2015 10:28 PM
