petrol guage
Old Feb 4, 2009 | 09:27 AM
orion88's Avatar
orion88
Default petrol guage
ive just converted from mfi to efi but te petrol guage aint reading.now i now theyre is power to the sender on the black and yellow wire but the guage is not reading anyrhing.any ideas?
Old Feb 5, 2009 | 01:41 PM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
i had to change to efi clocks so the tacko whould read right n as a plus it made the fuel n temp gauges work dont now is that helps
Old Feb 7, 2009 | 11:57 PM
orion88's Avatar
orion88
did ur mfi clocks read absolutely nothing?
my temp works bang on but my petrol guage goes down intead of up?know the rev counter dnt work but i nee petrol
Old Feb 8, 2009 | 07:27 AM
tommytxr's Avatar
tommytxr
no tacko was reading half cos of the wasted spark on efi n the fuel gauge was always abit iff. but your gauges sound more wire crossed wires when you changed looms was it with a full efi loom or was it cut on the off side so you had to solder the two together?
Old Feb 9, 2009 | 12:26 PM
orion88's Avatar
orion88
well i can only assume its been out of an xr3i and the fieta engine management pulgged in after
the gauge has power cos it shoots straight to nil i used another set of mfi clocks and the gauge was at half full plugged it in and it shot down to 0 it didnt fall slowly i mean it shot down and there is 40quid in the tank.my temp guage is fine tho reads well all the time but the petrol aint.i tried pouttin the eart on the tank as apparently this will shoot the clocks up to full but it just spaked alot.im stumped now and have no idea how much fuel is init
Old Feb 12, 2009 | 09:41 AM
orion88's Avatar
orion88
anyone?
Old Mar 19, 2009 | 10:16 AM
orion88's Avatar
orion88
BTTT
Old Mar 21, 2009 | 08:55 AM
Toe Knee's Avatar
Toe Knee
you dont earth the tank mate!! to check if the gauge is working ok you get the wire going to the gauge and earth that off and then the gauge should shoot up then come back down when released. Its gota be something to do with how its wired, i converted the gfs car to efi and the fuel gague still works fine with the old mfi clocks and efi clocks!! the temp gauge doesnt work properly as it never seems to get to temp but im hoping thats due to a dodgy stat staying open. Ive got the rev counter problem too thou, even with the efi clocks it doesnt register properly so ive gotta get another set of efi clocks too see if its that or not!!
Check to make sure the sender wire goes from/too the tank/sender ok and you have continuty going to the gague from it too with a multimeter!!
timsrs
Nov 13, 2018 11:48 AM
mk1turboestate
Dec 2, 2015 08:31 PM
15
Oct 7, 2015 03:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Brickhouse
Sep 21, 2015 11:00 AM
