im in need of a cvh guru
Welsh And Proud
im in need of a cvh guru,reguarding my 1.6 8v xr2i engine,as i would like to know what is needed to make it a turbo engine like the fiesta
thanks,Andy
thanks,Andy
i'm no guru but from memory the pistons are obvously different, obviously you can turbo it as it is but then u cant run alot of boost, you'll need a turbo exhaust manifold and turbo, and the downpipe is gonna be different on the exhaust, cant remember if they run the same injectors off hand, but the other things you'll need is the turbo ecu.
Then it would all depend what car its goin in?! if the cars a 2i too the map sensor connectors are different so will need changing, not 100% sure if the 2i loom is ok to use other than that or if you'd have to swap it for a fez turbo loom.
If its going into an escort then you ideally need an efi loom or you can splice a fiesta turbo loom into an mfi car too but isnt as neat!!
Welsh And Proud
its going into my xr2i.i lookin to turbo the cvh as its the same as the frst.i know the pistons are diffrent and thats as much as i relly know.
Best thing to do is get hold of a decent Turbo engine from a fez, drop a T3 on there from an ERST then just use the loom from the FRST. You will need a few other bit of course like I.cooler etc but thats the way i would probably do it. Std boost on a non turbo engine will be ok for a while but you will be wanting more later on!
Welsh And Proud
Engine
Type: CVH
Capacity: 1596cc
Bore/stroke: 79.96mm x 79.52mm
Compression ratio: 8.2:1
Max power: 133 bhp @ 5500 rpm
Max torque: 135 lbf.ft @ 2400 rpm
Cylinders: four, in-line
Cylinder head: alloy
Block: cast iron
Installation: front-mounted, transverse
Valve gear: two valves per cylinder, belt driven overhead camshaft
Induction: Garrett T2 turbo, intercooler, Ford EEC-IV engine management
Type: CVH
Capacity: 1596cc
Block: cast iron
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
