cvh oil pump ?????
Old Jan 23, 2009 | 12:11 PM
endoed's Avatar
endoed
in a mess with wires!!!!!
Default cvh oil pump ?????
hi all my oil light stays on when the car ticks over and when i rev it the light goes off the bloke who i bought the car from said he has had a new switch fitted it looks new to me so i dont think its that the car runs spot on with no knocks or rattles could it be the oil pump are they easy to change ?????
Old Jan 23, 2009 | 12:20 PM
B16CVH's Avatar
B16CVH
Get the oil pressure checked first, if the switch is working and the light is on you could well have some engine wear
Old Jan 23, 2009 | 12:29 PM
endoed's Avatar
endoed
the sump has been bodged up with some sort of mastic would this make the oil pressure wrong ???
Old Jan 23, 2009 | 12:33 PM
t31ryt's Avatar
t31ryt
what oils in her??
Old Jan 23, 2009 | 12:36 PM
endoed's Avatar
endoed
Originally Posted by t31ryt
what oils in her??
not sure
Old Jan 23, 2009 | 12:43 PM
t31ryt's Avatar
t31ryt
its just that mines the same and have been told to try different oil
Old Jan 23, 2009 | 12:46 PM
endoed's Avatar
endoed
ah ok well with a bit of luck someone on here will shed some light on it
boothy's Avatar
boothy
for starters.get rid of that sump you dont know how well its sealed. then take it to a garage and get a pros opinion
Old Jan 23, 2009 | 12:49 PM
endoed's Avatar
endoed
i think my best option is to replace the sump and check the pick up at the same time if it ever stops raining lol
Old Jan 23, 2009 | 03:28 PM
I'd certainly do the sump, a lot of pattern panel people do sumps as well like Hadrian.
It may well be the case that owing to the bodge the car suffered oil loss which has caused some crank/shell wear and that is why the light is on at tickover.
It would be wise to do an oil change and flush too.
If it is only on at tickover I would just put up with it, otherwise you will spend a lot of money on a rebuild when you could have many thousands of miles yet from this engine.
I have had cars that took 10 seconds for the oil pressure to build enough to stop the knocking before now, and still had a fair few thousand out of them, the old triumph sixes were famous for this, from new, as oil draine dback from poorly designed system but still would do over 100,000 miles.
Old Jan 23, 2009 | 04:25 PM
B16CVH's Avatar
B16CVH
You could always check the shell bearings while the sump is off and renew if worn to prolong the engine that little bit longer.
Old Jan 23, 2009 | 04:32 PM
tocca's Avatar
tocca
My old engine used to bring the light on at idle. I left it and after a while it killed the engine. Cause was an oil pump. Can be a pig of a job in place mind you
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 27, 2015 04:55 AM
Eigdoog
48
Sep 19, 2015 11:03 AM
talon1
Sep 15, 2015 10:27 AM
