zetec turbo
Old Dec 15, 2008 | 06:35 PM
Phil2002's Avatar
Phil2002
Default zetec turbo
Hi can any one tell me what crank sensor i need to use on a zetec block when running fiesta turbo managment please.
cheers,
Phil
Old Dec 15, 2008 | 06:41 PM
crazycage's Avatar
crazycage
cheers,
Phil
what flywheel did you use??
Old Dec 16, 2008 | 07:57 AM
Whichever one you can get to line up best with the proper gap.
Old Dec 16, 2008 | 06:38 PM
Phil2002's Avatar
Phil2002
was gonna use the frst one.
Old Dec 16, 2008 | 06:51 PM
crazycage's Avatar
crazycage
then use the fiesta sensor then mate thats what i did on mine and its fine
Old Dec 16, 2008 | 07:31 PM
Phil2002's Avatar
Phil2002
blindin' thanks for that mate much appreciated.
Cheers,
Phil
Old Dec 16, 2008 | 07:35 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
on a 2litre zetec can u just bolt fiesta rs turbo inlet manifold on then?with no mods?
Old Dec 18, 2008 | 04:25 PM
crazycage's Avatar
crazycage
no you need an adaptor plate
Old Dec 19, 2008 | 06:50 PM
Phil2002's Avatar
Phil2002
you'll need to plates one to allow you to bolt it to the head and the other is a spacer plate that goes inbetween the two halves of the inlet to raise it up by 13mm so that the throttle body can clear the zetec cam cover.
Old Dec 28, 2008 | 08:29 PM
HOL's Avatar
HOL
Has anyone else done this in KENT, im thinking of putting one in a kitcar.
Old Dec 28, 2008 | 08:37 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
done what the zetec turbo conversion?
Old Dec 29, 2008 | 08:36 AM
HOL's Avatar
HOL
yes,
I would prefer to see one in situ so I can gauge the issues in fitting it to a caterham type car.
Currently got a zetec 1.8 on carbs.
Old Dec 30, 2008 | 06:16 PM
clarke5700's Avatar
clarke5700
yes,
im prity sure ive seen a wastfield with a zt
Old Dec 30, 2008 | 07:28 PM
Phil2002's Avatar
Phil2002
there is a guy on here who has a high spec zt engine a yellow caterham not sure of his name i'll have a look through some old posts to see if i can find out.
cheers,
Phil
Old Jan 5, 2009 | 07:48 PM
timhil's Avatar
timhil
im getting a 1.8 zetec engine for my frst or maybe the 2.0 but does anyone no what the best series to go for is for both these engines? and is the easiest to work with turbo and fit ect?
Old Jan 5, 2009 | 08:19 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
There's no replacement for displacement!
Old Jan 5, 2009 | 08:30 PM
B16CVH's Avatar
B16CVH
In this case listen to a womans advice (but only this time)......Bigger is better!
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
