Comments/advice on my engine spec please
Old Dec 12, 2008 | 09:22 AM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
Default Comments/advice on my engine spec please
Ive just recieved my block back from my engine maker, it was supposed to be a 2.0 zetec block with farndon rods and wiseco pistons with a comp of 9:1. I have found it has standard rods and accralite pistons with a cr of 8:1. It is now being reassembled with pec h section rods. I am a bit worried as I have heard bad things about accralite pistons, This is a fresh build using a new block and crank, both standard but like I say new. Will this engine spec be good and strong for running about 16psi??? Are the pec rods less quality to the farndon ones??
any advice would be great
Old Dec 12, 2008 | 09:31 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
its not so much the boost its how well its mapped as well i wouldent worry about the pistons as long as they are in good condition you should not fined then a problem have u had a zvh or zetec turbo built as for boost im running that on standard rods if you are useing a new unground crank as you say with them rods i would say you could run any think up to 25psi but agan its all down to how well its set up what car is it going in?
Old Dec 12, 2008 | 09:38 AM
Raj_FRST's Avatar
Raj_FRST
Thanks for the reply, here is the proposed engine spec:
new 2.0 zetec block
New zetec crank
new standard size bearings
new PEC H beam rods
new Accralite pistons (8:1 cr)
Dark Green 440cc injectors (maybe 400?)
stage 2 head, ported but standard size valves
new standard cam
new stage 3 t3 cossie turbo
new gotech management (to be mapped by mark/jamie at jamsport, top lads)
usual other stuff
do you think this should be strong enough for a fast road car? it is a freshly built engine using mostly new parts
P.S. It is going in my fiesta mk3 rs turbo demo car
Old Dec 12, 2008 | 11:13 AM
clarke5700's Avatar
clarke5700
it will be more than up to the job the next thing you should look at is gear box tho that is a good spec engine (better than mine lol) what g-box are you useing?
clarke5700's Avatar
clarke5700
also is it a zvh or full zetec?
Old Dec 12, 2008 | 11:31 AM
Raj_FRST's Avatar
Raj_FRST
thanks for getting back, it is a zvh and i have a cts stage 2+ box:
quaiffe diff
uprated bearing
shot peened cogs
im worried a bit about the pistons as they were machined by burton power to make the cr 8:1, are b-power competent? will these pistons last me a few years?
Old Dec 12, 2008 | 11:37 AM
clarke5700's Avatar
clarke5700
burton power have been machineing pistons for years a block i work with noes stev burton very well. you wont have a problem with your pistons at all imo.
dont no who they are to be fair i would talk to ian at area six as he has been building the and mapping the zvh for years. or evon MSD
Old Dec 12, 2008 | 11:41 AM
Raj_FRST's Avatar
Raj_FRST
spoke to ian a few times, very clever bloke and always offers sound advice, I have tried contacting msd a few time but fell on deaf ears. shame.
Jamsport seem very helpful so I will be taking the car there for the aftermarket managament conversion and the mapping.
glad the engine will be ok for me, was having a bit of a panic moment there.lol
Im hoping the engine should produce about 220bhp with plenty of torque at about 15psi, finger crossed
Old Dec 12, 2008 | 11:44 AM
clarke5700's Avatar
clarke5700
nahhhhhhh after you have run it in crank the boost up to 20psi see what it makes then lol
Old Dec 12, 2008 | 11:50 AM
Raj_FRST's Avatar
Raj_FRST
LOL, fuck that, knowing my luck I would have a cond rod or piston sat next to me in the car!!!lol
do you think im unrealistic with my forcasted power figure for the boost??
This is my first zvh project so I may be way out
Old Dec 12, 2008 | 11:52 AM
clarke5700's Avatar
clarke5700
yea sounds realistick to be fair i havent had much to do with them more so the zetec tbh just see how it goes and let me no how you get on lol
Old Dec 12, 2008 | 11:56 AM
Raj_FRST's Avatar
Raj_FRST
ive got a thread in the reso forum, its called 200bhp fiesta, will be updating it this weekend, keep your eyes peeled as instead of rebuilding it concourse as every other person does (they all have bottomless wallets) im doing it on a realistic budget.
The car is going to be a fast road car and hopefully should be able to mix it with the big boys, ideally keep up with my br's 300bhp sti or my sisters evo 8 (git & bitch) lol
JoeyBoyden
Jan 4, 2024 02:36 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Oct 9, 2015 07:38 PM
3drRich
Sep 13, 2015 07:32 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
