Turbo shaft movement limits.
Old Nov 5, 2008 | 10:23 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Talking Turbo shaft movement limits.
Hi guys,
Is there any guidelines as to how much side to side movement is acceptable in a turbo.....I understand it must vary across different size turbos but there must be a rule or guides to go by.....wiggling it and judging its condition is ok if you know what your looking at but I unfortunately havent purchesed many 2nd hand turbos.
So my main question is how much shaft play (side to side) should I expect on a new t38 turbo and at what measurement should I start to think about rebuilding?
Dan
Old Nov 5, 2008 | 10:24 PM
SillyFezzaMk1
Rubber Rhino Crew
forgot to say i'll use digital vernier calipes to measure shaft play from the compressor housing.
Dan
Matt Baxter
Sep 16, 2015 08:30 PM
borboyous
Aug 22, 2015 11:17 AM
RockinRein
Aug 19, 2015 07:08 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
Churtz
Aug 3, 2015 08:19 PM
