focus rs into mk2 xr2?
Old Nov 5, 2008 | 02:34 PM
ian1411's Avatar
ian1411
super fly
Question focus rs into mk2 xr2?
will it work and wot will be needed to do the conversion?cheers
Old Nov 5, 2008 | 02:40 PM
FOCUSTARD PIE's Avatar
FOCUSTARD PIE
A focus rs and lots of money !
Old Nov 5, 2008 | 02:47 PM
ian1411's Avatar
ian1411
super fly
mint!! its not 4 me its 4 a m8.so guna need full running gear and loom,will the engine fit onto a s2 box or will he need to use the focus box cheers
Old Nov 5, 2008 | 02:49 PM
prwoodford's Avatar
prwoodford
teamwoodspeed
I've seen a few ST170s and 2 litre Zetecs mounted in Mk1/2 bays now, and it's been proven that a Cossie turbo lump will go in, so as far as will it work is concerned the answer has to be yes - if you have the appropriate fabrication ability it should be ok with perhaps some trial and error.
Old Nov 5, 2008 | 02:50 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
you would be better to use the focus box as its stronger, but you will most certainly be required to modify the shell, specifically engine bay and have drive shafts, engine mounts, gearbox mounts etc made.
very big money build imho
Old Nov 5, 2008 | 03:54 PM
dunketh's Avatar
dunketh
Chief Iron Oxide Farmer.
Its gonna torque steer like a tw*t!
The standard 1600 makes the car steer wherever it likes already.
Hope you've got some extensive suspension & ARB mods to go with it.
Will be an animal though.
Old Nov 6, 2008 | 11:38 AM
ian1411's Avatar
ian1411
super fly
thats the plan i think mate,plus its sumat out of the norm.its already on coilovers and uprated bushes and i think he is goin fully adjustable underneath aswell.cheers 4 the advice
Old Nov 6, 2008 | 11:42 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
i tracked xr2-si zetec turbo it reduced this alot.
TPM961
Jan 15, 2018 10:50 AM
richierich1986
Sep 18, 2015 03:29 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
