Zetec building crank wont turn
Did a dummy run of assembling the bottom end of my ZVH today, and the crank is really tight (ie need to swing on it with a long bar to get it to turn) with the main caps just nipped up, new std size bearings and all new bolts etc.
Is it more likely that the crank is bent or that the caps are from another block? The caps weren't bolted up when I picked the block up and the crank was wrapped up in a curtain![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Ta if anyone can help
Checked all the clearances with plastiguage and they were all sound, so put it together with a load of graphogen and its perfect now! No tightness anywhere, no grinding noises and the end float is within tolerances so its all good![Top](https://passionford.com/forum/images/smilies/smile011.gif)
I must have left some grit or other shite under the shells or summat?
Roll on getting the head done and I might hear it running before crimbo![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Cheers for the replies lads
![Smile](https://passionford.com/forum/images/icons/icon7.gif)
Ta if anyone can help![Top](https://passionford.com/forum/images/smilies/smile011.gif)
JoeyBoyden
04-01-2024 02:36 PM
James Porter
28-10-2015 12:17 PM
The Underdog
29
07-09-2015 09:49 PM
CabrioTurbo
01-08-2015 11:04 AM
