Anti-lag question....
Old Aug 30, 2008 | 09:37 PM
brizer's Avatar
brizer
Default Anti-lag question....
Hello guys,am building a mk2 with a cosworth engine for track days etc and was thinking of putting anti-lag on it... is it just a matter of changing the ecu ???
I have a L6 ecu with an upgraded chip... any help would be appreciated
thanks
Old Aug 30, 2008 | 09:44 PM
Barry R's Avatar
Barry R
you need a mar m 247 shafted turbo aswell and modified idle valve
Old Aug 30, 2008 | 10:27 PM
Rs1's Avatar
Rs1
Depending on the severity of the ALS you dont have to have the 247 or ICV mod.
Tbh it'll be rare that you'll not get black flagged for running ALS on a track day, its not worth the hassle imo.
MSD can do ALS/launch mods to L8, unsure about L6.
Old Sep 1, 2008 | 06:39 AM
As said don't need the special shaft if you only want low/ish al, plenty of aftermarket ecu's support/run anti lag, to any degree that you want.
Old Sep 1, 2008 | 12:01 PM
Barry R's Avatar
Barry R
I didnt know that so what do you need for mild als then
Old Sep 1, 2008 | 12:22 PM
cozmeister's Avatar
cozmeister
More boost Igor!
A maram shafted turbo, a modified Idle Control Valve, an ECU that supports running anti-lag. If you're sticking with the the Weber ECU (for example ), and using an 'MSD' L8 in place of an L6, you'll need the PF09 TPS to go with it.
And most important of all....shares in Shell
Old Sep 1, 2008 | 03:29 PM
Barry R's Avatar
Barry R
umm read the whole lot again
Old Sep 1, 2008 | 03:50 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Again, I miss the point.... I'll go back to sleep.
Old Sep 1, 2008 | 03:57 PM
Barry R's Avatar
Barry R
they are saying you dont need the mar m or modified ICV
Old Sep 2, 2008 | 07:36 AM
Aaroncast's Avatar
Aaroncast
Wink
--------anti lag on track day--------lol
-------- sainsburys car park next???
genuine competitor then!!!
Physio
17
Apr 25, 2007 09:26 AM
leecavturbo
23
Sep 22, 2006 03:55 PM
Carlsworth
Aug 3, 2006 12:29 AM
Jon(m600)
Jun 14, 2005 07:22 PM
M.A.D.RST
17
Oct 7, 2004 08:00 PM
