Roller bearing turbo?
Question....
What are the advantages of a roller bearing turbo over a standard turbo & would you notice a hugh amount of difference on spool up?
Hi AJ
as standard the evo's have better turbos than the cossies anyway
with the GT turbos it all depends on spec gt28's are good for 400+ and spool up really quickly from as little as 2k rpm
my internal Gt30 spools up from about 3k in 1st gear just like my T34 with .63
i dont have any "sergio" taccini at all and kicks like a mule and twice as hard
marco
marco
Re: Roller bearing turbo?
Originally Posted by AJ THE PF GOD
Question....
Mark
#1 in Spelling Club
Originally Posted by marco polo
Hi AJ
marco
marco
Cheers for the info people
I've got titanium inserts in my turbo & have hardly any lag at all
Also, the low-lag thing is more to do with the turbine housing design than anything else IMO.
Question....
Mark
See you soon for a re-map
[quote="Christian and Beccy"]
Hi Chris
where you been for the last 3yrs
Ian 3dr white cos made 404bhp with 400 ftlbs torque
i thought you knew that
marco
Marco, I haven't seen a GT28 make over 400bhp on a 2.0 engine, has anyone got proven results for this?
marco
DEYTUKURJERBS
[quote="marco polo"]
Hi Chris
marco
Not a genuine GT28 tho, some mental T35 hybrid isnt it.
GT2871Rs are rated to 400 tho.
marco
[quote="Stavros"]
Hi Chris
marco
Hi Steve
I have not got a clue what it was , it was most defo gt28 front compressor and core but not sure of rear housing it made just over 400+ bhp on the dyno
marco
marco
marco
Not welcome...
Hi Chris
marco
can you let me know who the builder of this engine was or point me in the right direction of Ian 3dr for a chat please?
Thanks
marco
Thanks
Tests have shown that ROLLER BEARING turbos have a much lower drag than floating bearing type.
They used on tests 200 watts of power to rotate at a given rpm, compared with 800 watts for a traditional floating bearing design at the same rpm.
So they have less drag, will therefore spool quicker as less force trying to keep them still, and influence their behaviour.
One of the other main benefits is they can be sealed a lot better/easier to prevent oil consumption.
Former Sponsor
ayyyyyyeeee
big difference between the roller bearing turbos and the ball bearing turbos..
roller bearing can be fixed, ball bearing turbo once they let go need a full chra in many cases, so usually very expensive to fix, close to the price of a new unit
carl
Or are you talking 400 at the wheels?
Below is the link, he's managed an 11.3 second 1/4 mile also
https://passionford.com/forum/viewtopic.php?t=151775
JK12
33
26-04-2021 12:09 PM
