Putting a 3dr back together!!
Old Aug 30, 2008 | 11:26 AM
B2RJT's Avatar
B2RJT
Default Putting a 3dr back together!!
Hi there,
I am in the process of rescuing a 3dr from the jaws of the crusher. I will post pictures of it's journey shortly, but at the moment i am struggling to get the gearbox to sit correctly. could well be a saph box and mount but didn't think there was any difference in shape. The other problem is I've just attached the RS500 style intercooler and now the headlights wont go back into their holes! Assuming I'm right in mounting the intercooler in front of the rad?
any help would be great as i've no experience in this sort of thing!!
Old Aug 30, 2008 | 11:27 AM
rsnissan's Avatar
rsnissan
are you using a saph gearbox bracket to support it under the tunnel?? the 3dr ones are different.
Cooler goes infront of the rad, do you know what make it is?
Old Aug 30, 2008 | 11:34 AM
B2RJT's Avatar
B2RJT
cooler is a forge and i assume i've got a saph mount!
Old Aug 30, 2008 | 11:42 AM
rsnissan's Avatar
rsnissan
3dr mount
Old Aug 30, 2008 | 11:50 AM
rsnissan's Avatar
rsnissan
cooler sits about here
Old Aug 30, 2008 | 12:02 PM
B2RJT's Avatar
B2RJT
thanks a million, my cooler must be sitting too far forward then. Strange as i have used the original holes under the chassis rails. Now all i need to do is source the correct gearbox mount and i'm nearly there. If anyone on here has one it would save a massive amount of hassle, if not i'll see if they can still be bought through ford.
Old Aug 30, 2008 | 12:04 PM
rsnissan's Avatar
rsnissan
There are two sets of holes one for the rad and cooler so make sure you have the cooler on the correct ones.
The mount I doubt you can get from ford anymore unless anyone knows different. I think you can mod the tunnel to accept the saph bracket but again someone will confirm this.
Old Aug 30, 2008 | 01:31 PM
mk2rstaff's Avatar
mk2rstaff
it looks like you either have a saph or escort 500 cooler, i have one on my 3dr and it has small cut out at the top corners to allow the lights to go back in. i just got round it by putting the smaller lights in there instead.
billybob
62
Aug 25, 2015 07:21 AM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
john_3.0s
Aug 16, 2015 06:40 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
