cosworth fuel pump
Old Aug 15, 2008 | 05:35 PM
nobbie_b's Avatar
nobbie_b
Default cosworth fuel pump
alright guys is it worth upgrading to a group a fuel pump
Old Aug 15, 2008 | 05:48 PM
Staffi's Avatar
Staffi
Depends on your spec, then yes..
Old Aug 15, 2008 | 05:50 PM
nobbie_b's Avatar
nobbie_b
if i am going to be looking for about 400 bhp at the fly is it worth it
KSA-Cossie's Avatar
KSA-Cossie
Most definately and rewire your pump wiring too m8.
Old Aug 15, 2008 | 05:52 PM
Staffi's Avatar
Staffi
As Kev says ^^^^
Old Aug 15, 2008 | 06:05 PM
nobbie_b's Avatar
nobbie_b
a complete re wire of just the terminals to the pump
Old Aug 15, 2008 | 06:13 PM
LHD220Turbo's Avatar
LHD220Turbo
rewire from battery direct to pump with new cable (& earth)...dont for get to fuse it
Old Aug 15, 2008 | 06:17 PM
nobbie_b's Avatar
nobbie_b
ok will do, surely you have to run it through the ignition as it will be on all the time though
Old Aug 15, 2008 | 06:35 PM
KSA-Cossie's Avatar
KSA-Cossie
No the original wiring activates the relay which switches the new wiring.
Old Aug 15, 2008 | 06:38 PM
LHD220Turbo
as above
you're only replacing the feed and earth; not the relay!
Old Aug 15, 2008 | 10:39 PM
nobbie_b's Avatar
nobbie_b
ok cheers guys just wanted to clear that up thanks for the help
Old Aug 16, 2008 | 07:06 AM
Make sure you keep it through the cut out bit safer that way.
I mounted my realy up at the back of the rear seat inside the boot, so if going to show etc just pop relay out of it's holder for a little extra free security.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
