steering wheel shakes when braking
Old Jul 9, 2008 | 08:22 PM
b14dave's Avatar
b14dave
Default steering wheel shakes when braking
has anyone had or know of what causes my steering wheel to shake when applying the brakes
had new discs tryes and wheel balancing done could it be a warped hub
Old Jul 9, 2008 | 08:26 PM
s1cab's Avatar
s1cab
suppose it could be. what car is it on?
Old Jul 9, 2008 | 08:34 PM
s1cab's Avatar
s1cab
a wheel could be slightly buckled ?
Old Jul 9, 2008 | 08:41 PM
b14dave's Avatar
b14dave
its a 2wd sapphire
Old Jul 9, 2008 | 08:44 PM
JPA's Avatar
JPA
if the work youve had done is al ok and no faulty parts , then prob need tca bushes changed mate
john
Old Jul 9, 2008 | 08:48 PM
b14dave's Avatar
b14dave
tcas been replaced their original ford cant get my head round it
only when you brake you get a shake, not a voilent shake just like a wobble on the wheel
Old Jul 10, 2008 | 05:09 AM
Check for sticky caliper pistons.
Old Jul 10, 2008 | 06:33 PM
zetecdan's Avatar
zetecdan
i had something similar on my mondeo. After replacing the front discs it was no better, a mate said its the rears so i reluctantly replaced them and hey presto no more juddering.
Old Jul 10, 2008 | 06:44 PM
moesin2005's Avatar
moesin2005
i had this on my series 1 swapped discs etc no better then found out one of the front shocks was knackered swoped that and it was ok
Old Jul 10, 2008 | 07:55 PM
cossie legend's Avatar
cossie legend
Clamp off each flexible hose at a time and take her for a run. At least you will find out which side it is.
Old Jul 10, 2008 | 08:15 PM
Riggie's Avatar
Riggie
Series 1 RS Turbo
i can probably answer this right here and now..... and its an easy fix.
theres a bush on your steering column were it goes through the bulkhead. i bet you any money that if you knock this back flush to the bulkhead that it will sort the problem. this happened to me on my 4wd saph when i fitted a new steering column. i had my brakes, wheels, bottom arms etc checked and couldnt find the problem. i asked the ford mastertech at work and it was sorted it 10mins.
you can atleast try it and eliminate it...
good luck mate.
Riggie.
Old Jul 10, 2008 | 09:51 PM
b14dave's Avatar
b14dave
ok ill have a look,
its mainly about 50mph any faster or slower and it no their
Old Jul 10, 2008 | 10:34 PM
Saaamon's Avatar
Saaamon
Check all the bushes with the wheels on the ground and jacked up, had the same problem on my car and at the same speed aswell.. Found out it was tca bushs and bottom ball joints.
Old Jul 10, 2008 | 10:35 PM
james kiely's Avatar
james kiely
my saff does the exact same ,i had a look and the bottom bush on the steering column looks knackered, yet it only does it sometimes.sometimes there is a loud clunk when on full lock,would the bottom bush cause this[will check the bulkhead tommorow]
Old Jul 11, 2008 | 08:01 PM
Riggie's Avatar
Riggie
Series 1 RS Turbo
yeah, mine does that 'clonking' noise, it only vibrates on braking at approx 50mph, and at times it can feel quite violent.
the thing to do is tap the bush back into the bulkhead, and with a centre punch, punch a hole into the shaft just after the bush. this is suppose to stop the bush falling back down. who knows you might even be able to put a 'jubali clip' (spelling!) on the shaft to hold the bush in. just a possibility.
Riggie
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
