1.6 Zetec Reving Problem
Old May 14, 2008 | 07:51 PM
Dover Shark's Avatar
Dover Shark
Default 1.6 Zetec Reving Problem
HELP PLEASE :- I own an Escort Mk 6 with a Zetec 1.6 engine on an R plate & its driving me nuts.The problem is when starting from cold & sometimes hot,the engine runs at between 1500 & 3000 revs.Now for the bit that I just can not get my head around (nor can anyone I have spoken to) If I drive a mile or so up the road & stop at a junction,the revs drop as they should to about 900 revs,all is well you might think,BUT,if I do not have to stop I can drive for miles & while I am driving,if I take it out gear & coast the engine revs stay at 1500-3000 revs & will not go any lower.If I bring the car to a stop,as soon as the car is stationary,the engine revs will drop to its ideling revs & the problem then disappears.
I live in hope.
Regards
Sharky
Old May 14, 2008 | 10:09 PM
Wardy257's Avatar
Wardy257
Check and clean the Vehicle Speed Sensor.
Old May 15, 2008 | 06:09 AM
Don't bother with the VSS, vehicle speed sensor, the FACT that it holds the revs up when costing tells you it is getting a clean signal.
Try a new coolant temp sender for the ECU, NOT the temp gauge one, as idle sped is based upon operating temperature mainly.
Old May 15, 2008 | 09:31 AM
Dover Shark
Firstly,thanks for your replys,I have fitted a new Coolant Temp sensor as well as the temp gauge one.I have just tried to reset my ECU by disconnecting the battery overnight & doing what the,dare i say it,Haynes manual says & I will be trying the results later today when the engine has cooled down.I will let you know if it was successful.
I also now think that the Air Flow sensor (MASS) could be at fault as when the engine is running & I disconnect the multi-plug the engine runs as normal,no change in revs,if you rev the engine it runs as normal but should this not happen.
Thanks again
Sharky
Old May 15, 2008 | 10:01 AM
onslack's Avatar
onslack
might not be this but, have you had a look at and cleaned the ISCV?
Old May 15, 2008 | 01:35 PM
Some will run with MAF disconnected.
To reset the ecu, you do not need to take the battery lead/s off at all.
Look in the main fusebox under the bonnet, in there will be a fuse of 3 AMPS, this will be marked KAM, just take this out for 1 minute, put back job done.
KAM stands for Keep Alive Memory, it stores the fine tune settings of the engine running.
Old May 15, 2008 | 02:40 PM
Dover Shark
I have just got back after a run,it has improved it but not cured it.I will try removing the said fuse but after disconnecting the battery I assume it was to the same effect.
I will also try to clean the ISCV but excuse my ignorance as I do not know what it is or where it would be located.
Excellent Forum,Helpfull & Friendly.
Sharky
Old Aug 27, 2009 | 12:57 PM
phil hoggart's Avatar
phil hoggart
i have the same problem with my cabriolet 1600 zetec
i have removed the ISCV and cleaned it , no help , fitted a new coolant sensor
when we got the car i did a big service with all the fuel filter , air filter , oil and filter , plugs , leads, cambelt and tensioner and V belt but it made no differance
we went to the ford garage today and they tell me we need a new ECU
i have been around fords for a few years but have never heard of this ??
any advice because the ISCV is €150 and a new ECU will be about €1500 fitted and programmed , i can use a 2nd hand one but still needs to be programmed !!
Please help
cheeRS Phil
Old Aug 29, 2009 | 04:08 PM
phil hoggart
Please help
cheeRS Phil
any one ??
Old Aug 30, 2009 | 09:19 PM
martysmartie's Avatar
martysmartie
I think it's VSS.
Martin
Old Aug 31, 2009 | 05:27 AM
phil hoggart
is that the Vehicle Speed Sensor ??
it does it when the car is stationary too ???
gcfcos
88
Sep 15, 2015 03:48 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
