strange EFI cold start prob
Old Oct 17, 2004 | 11:33 PM
Windle's Avatar
Windle
Default strange EFI cold start prob
EFI series 2 rs turbo been fine for months, just decided last week not too start when its cold? battery cranks engine over for a good few mins so it aint flat just wont go. if i bump it it runs fine, then will start on its own again untill left for say more than 5 hours
any ideas as the old people at work are fed up with pushing it everyday
Old Oct 18, 2004 | 01:16 AM
blaazer2's Avatar
blaazer2
check the cranking voltage to the coil ,or it could be a lazy starter motor sapping all the current
Old Oct 18, 2004 | 07:38 AM
JesseT's Avatar
JesseT
The EDIS-4 box seems to be quite picky about the voltage it gets. I fit doesn't work properly, it doesn't give a trigger signal to the EEC-IV box. Try if cranking with lights, fan, radio, ... disactivated helps.
Well, it's a long shot, but anyhow first check if you're getting a spark. If not, then you have isolated the problem pretty well.
Old Oct 18, 2004 | 08:17 AM
Windle's Avatar
Windle
hi thanks for the starter points, it cranks over with noting on at all will sit there cranking for 3 mins but will not fire i am sure it turns too slow as it seam too turn much faster when its warmed a little. if i turn whilst in gear as soon as i get the car moving a little engine speed increases and car will then start.
Old Oct 21, 2004 | 10:00 AM
blaazer2's Avatar
blaazer2
Default starter
get a new starter ,make sure you fit a heat shield
Old Oct 21, 2004 | 10:01 AM
blaazer2's Avatar
blaazer2
Default starter
fit a new starter and make sure it has a heat shield
Old Oct 21, 2004 | 11:05 AM
JesseT's Avatar
JesseT
Doesn't sound at all like a starter problem to me...
Old Oct 21, 2004 | 04:57 PM
blaazer2's Avatar
blaazer2
Old Oct 29, 2004 | 03:24 PM
Windle's Avatar
Windle
i have the zorst all heat warpped up starter is fairly new as this used too be lazy when warm untill i heat wrapped it
now as i say after 5 hours engine just doesnt turn over fast enough it seams
Old Oct 31, 2004 | 09:19 AM
A.Moore's Avatar
A.Moore
Seems you do have an electrical problem, as cranking i believe you should have a stronger spark.I've heard a few times about this problem over the years so it must be fairly common, try phoning so of the tuning guys who have more running problem knowledge.Al.
kevin36
Sep 2, 2015 06:24 PM
Dahl88
Aug 22, 2015 08:16 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
