S2 Boost Problem!!
Old Dec 31, 2007 | 04:39 PM
FelthamRST's Avatar
FelthamRST
Default S2 Boost Problem!!
hey guys, my ERST playin up yet again but hey im sure i dnt have to tell u lot that!! lol....
just put a brand new t04e T3/T4 turbo on it. got everything sorted and running, BUT, the damn thing takes ages gettin the boost up and when it does, at about 3500 rpm, it only hits 5 psi and dont go no further, as well as that it spits out a little smoke from the exhaust till i let off and the smoke goes. ive played with the actuator and the bleed valve but just cant seem to sort it. the only thing i can think of is the wastegate dont cover the exit hole on the turbo and the exhaust gases are escaping thru that instead of spinning the exhaust turbine?! (just to let u know the actuator is nice n tight and should easily cope with holding the fumes inside the turbo providing the wastegate is covering the hole properly...)
any suggestions guys???
im in Feltham, Middx if any1 is close by to help.......
ALSO.... im selling the car too. i changed the turbo coz the old 1 was knackered and knew i cudnt sell it like that so any suggestions before i sell it or any1 who wants to buy it and knows whats the matter with it then pls msg me!!
cheeRS again guys.....
Old Dec 31, 2007 | 05:00 PM
andyuk's Avatar
andyuk
Default boost
may be your dumpvalve or amel valve if you have either of them fitted
Old Dec 31, 2007 | 05:31 PM
FelthamRST's Avatar
FelthamRST
na i aint got a amel valve and tried both dump valve on and off.
Old Dec 31, 2007 | 06:14 PM
Barry R's Avatar
Barry R
how much do you want for it
Old Dec 31, 2007 | 06:26 PM
FelthamRST's Avatar
FelthamRST
2500 ONO
tax till end of may
MOT till april/may
good condition..... can email with spec list and pics if u like - let me know ur email....
cheers mate
Old Dec 31, 2007 | 06:53 PM
andyuk's Avatar
andyuk
Default try
checked your boost pipes for leaks
Old Dec 31, 2007 | 11:02 PM
FelthamRST's Avatar
FelthamRST
yeah i mean i aint taken them all off and inspected them but i have checked them and they seem fine?!
Old Dec 31, 2007 | 11:19 PM
rsvan's Avatar
rsvan
a mate of mine just had the same sort of problem on his s1 and it turned out to be a hairline crack on turbo housing, wasnt visable from the outside either, only when it had been run for a wile and then the turbo was removed................
didnt buy it from a turbo place in brentford by any chance?
Old Jan 1, 2008 | 02:02 AM
FelthamRST's Avatar
FelthamRST
i fuckin hope it aint that! it was a turbo from the usa off ebay, brand new, seems to spin n stuff fine. just dont think a hairline crack wud let out so much boost without it bein obvious!
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
