Non starting Punto?
Hello,
With the winter drawing in my mrs' Punto has been struggling to start. Its slow to turn over and now it won't at all. I've been out this morning, bought a new battery and the fella put a multi-meter on it and it showed 12v. Still sounds sluggish to turn over, so i recharged the battery and soaked it with easy start, it got a bit excited but just gave up.
The cars driven daily, so its not old fuel. I've had jump leads from my scoob connected to it and still even wth the new battery its not happy and still turning over slow.
Am i right in starting to suspect the starter motor could be at fault?
any advice would be a great help
Thanks
Thanks
REALLY!!!!!!
HAVE YOU TRIED THE JUMP LEADS FROM ANY OTHER CAR YET?????????????????-----------------YOU DO ASK FOR IT DONT YOU!!!
LOL-HE-HE
PUNTO!!!LOL---------TRY THE BATTERY OUT OF A HOUSE ALARM BOX!!12 VOLTS-
REALLY!!!!!!
LOL-HE-HEPUNTO!!!LOL---------TRY THE BATTERY OUT OF A HOUSE ALARM BOX!!12 VOLTS-
Check connections particularly earth ones first are good and clean, try the lead directly on the starter, if still no joy it is starter, easy to do, but cheap enough recon Ł35/45.
If all else fails a match often works!!
Yeh the crank sensors always go on them. If you look on the timing belt cover you will see the connector and if you follow the wire down(on the exhaust side) you will find use sensor at the bottom held in by a 10 mm bolt.
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
seconded
