Escort GTI fuel pump problem
Old Nov 22, 2007 | 08:21 PM
Trist's Avatar
Trist
Default Escort GTI fuel pump problem
I was on the way home from work tonight and just as I was 5mins from home the escort died..
i turned the key and all the dash lights came on as usuall but no fuel pump noise.
I have tried the re set button under the trim in the drivers foot well but no good.
where is the fuel pump relay on them, is it worth checking that as a next step??
many thanks
Old Nov 22, 2007 | 10:18 PM
Bungle's Avatar
Bungle
Hi mate relays are on the top of your fuse box you'll need to undo the clips to drop the fusebox to access them
Old Nov 24, 2007 | 03:58 PM
Trist's Avatar
Trist
I found that so cheers, I replaced the relay with new one and checked the relay holder and it all looks fine??
gave the pump the hammer treatment to and still nothing? how can I check the pump?
need to get it sorted for work monday
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
