cosworth cams
Old Nov 8, 2007 | 06:58 PM
montecos400's Avatar
montecos400
Default cosworth cams
I have 7:6.1 compresstion with bd10 cams and a t34.63.
I have just bought a new cylinder head which I will get ported to the max.
What cams do you guys recommend..I want the car to have more low down and mid range power and response.
Old Nov 8, 2007 | 07:02 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
If you want low down and midrange, don't port the head, especially if you are using a T34.63, std ports , std exhaust cam and either a std inlet or a BD14 inlet for a bit more top end......
Old Nov 8, 2007 | 07:11 PM
montecos400
can I use a bd14 without having valve cutouts in the pistons?
Old Nov 8, 2007 | 07:33 PM
RWD_cossie_wil
I don't think so, but if low comp maybe? But I doubt it
Old Nov 8, 2007 | 07:41 PM
Jay,'s Avatar
Jay,
Sponsor
bd1os wont supply power till later in the rev range
ive tried this combo myself and wasnt at full chat till 4600rpm
xr4x4rs's Avatar
xr4x4rs
sure you ned valve cut outs anything above a bd10
thats why i got my low comp pistons with the cut outs, but i will be running a 7.2-1 c/r
Old Nov 8, 2007 | 08:09 PM
col cos1's Avatar
col cos1
i have twin bd14s,and my head is on last skim
and my cosworth racing pistons dont have cut outs and have been inspected and no valve crash
but im pretty low comp
Old Nov 9, 2007 | 08:28 PM
montecos400
what cams would bring the boost on a little lower if at all possible then.
Old Nov 9, 2007 | 09:15 PM
Jay,'s Avatar
Jay,
Sponsor
standard at the stage of tune
Old Nov 9, 2007 | 09:39 PM
montecos400
What if I had a gt30 or a t38 which I am planning to use....
Old Nov 9, 2007 | 09:43 PM
Jay,'s Avatar
Jay,
Sponsor
then you will need head work with a combi of a bd12 inlet standard exhaust or some have used a 14 inlet with a standard exhaust cam
Old Nov 9, 2007 | 10:07 PM
RWD_cossie_wil
Mate, decide EXACTLY what power and torque you want, and where you want it. THEN spec your engine or you will end up with a big pile of expensive mismatched parts
Old Nov 10, 2007 | 04:10 PM
montecos400
I have had my current engine for 3 years now. Built by myself and mapped by msd. covered 15,000+miles with alot of track and santapod visits. Just want a change and just gauging where to go.
I have I have 7:6.1 compresstion with bd10 cams and a t34.63.
Forged pistons in a linered 200 block with greys. I run ALS also.
I want 450-500 but with the lag slightly reduced or kept the same and I want the car to idle properly which I have never been able to do with the bd10's
I was thinking of changing the turbo to a roller bearing t38 from r and b and fitting standard exhaust cam and maybe a bd14. I have a new unskimmed head in 100% condition which I was going to get opened up a bit.
Any one with experience of this spec?
Old Nov 10, 2007 | 05:33 PM
rapidcossie's Avatar
rapidcossie
why could the car not idle on the BD10's?
Old Nov 11, 2007 | 12:57 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Standard exhaust cam will bring the torque in a lot sooner in the rpm range.
Old Nov 11, 2007 | 02:54 PM
montecos400
It does idle but not as smoothly as it could. I was told by a few tuners this is what happens with two bd10's fitted as they overlap ?????
Old Nov 11, 2007 | 02:57 PM
Jay,'s Avatar
Jay,
Sponsor
and they are right thats how mine was until a changed back to standard
Old Nov 11, 2007 | 07:23 PM
garyrs's Avatar
garyrs
hi jay , i have a bd12 inlet and standrd exhaust i have looked up the lift and duration of this cam and it seems to have less lift than a bd10 and standard cam
burton list
bd10-lift 8.6 duration 264
stock -8.5 -241
bd12 -8.4 - -247
so has it got a differnt lift rate to a bd10 and standard ? or am i missunderstanding
cheers gary
Old Nov 11, 2007 | 07:58 PM
FROMFIFE's Avatar
FROMFIFE
I have BD10 inlet BD14 exhaust, car pulls from 2000rpm right up, 360 ATW.[/img]
Old Nov 11, 2007 | 09:24 PM
NEIL A's Avatar
NEIL A
Alan said your car came on boost real early and worked well with those cams, im going for something a bit lairyer so see what thats like.
You dont have a graph you can put up do you ?
Old Nov 13, 2007 | 10:18 AM
montecos400
Where can I get a roller bearing version of the T38
Old Nov 13, 2007 | 12:55 PM
NEIL A's Avatar
NEIL A
Think Harvey Gibbs is working on one justnow, not sure if it will be only available through him or if CR Turbos will be selling them.
Old Nov 13, 2007 | 06:18 PM
montecos400
right final question.
I have bought a T38 roller bearing turbo after good reports from some trusted people. Also bd14 inlet cam which will be used with a standard exhaust cam. My bottom end is already sorted. Aiming for the 450+ safe mark so last thing is the head spec.
I have a mint unskimmed head and want to know if the above spec can be reached without porting and polishing. I just dont want to spend a load of money on getting it re worked if it is just going to make the car less responsive etc.
Old Nov 13, 2007 | 11:27 PM
col cos1's Avatar
col cos1
im running twin bd14`s on a standard head (for now)
and my cams having been dialled in force the boost in earlier on midrange(t4)
but right low down its sluggish as hell
hope this helps you
Old Nov 13, 2007 | 11:32 PM
NEIL A's Avatar
NEIL A
Think the head becomes restrictive over 400 bhp you might make 450 but you will make it alot easyer and with less boost/stress on the engine if the head is ported.[/list]
JoeyBoyden
Jan 4, 2024 02:36 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Aug 14, 2015 07:29 AM
