rev counter for coil pack UP DATE ITS SORTED
Old Nov 5, 2007 | 09:49 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Default rev counter for coil pack UP DATE ITS SORTED
what tacho do i need to work with my wasted spark as my tacho will not work with the coil pack
stack would be nice but £££££££££ is there anything else i could use
Old Nov 5, 2007 | 09:56 PM
Jay,'s Avatar
Jay,
Sponsor
www.etbinstruments.com look at the vdo page matt
Old Nov 5, 2007 | 10:03 PM
Matt Baxter
Back in black!
nice one cheers Jay
more fcuking money
Old Nov 5, 2007 | 10:04 PM
Jay,'s Avatar
Jay,
Sponsor
its a fuckin cossie what do you expect
Old Nov 5, 2007 | 11:56 PM
Gatecrasher's Avatar
Gatecrasher
Not welcome...
Small turbo Escos thats what ive just got
Old Nov 6, 2007 | 06:08 AM
Matt Baxter
Back in black!
Old Nov 6, 2007 | 07:50 AM
D-Sport's Avatar
D-Sport
is this why my rev counter wont rev past 4 k since ive had the engine rebuilt and the new fangled distributar-less coil pack thingy??????????...............sorry bout the technical jargon
Old Nov 6, 2007 | 07:52 AM
Spiky's Avatar
Spiky
i make then looms, for the pug gti-6 boys
Old Nov 6, 2007 | 08:10 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Originally Posted by SordFish
This any good to ya?
The MSD wasted spark system already sends the correct number of pulses, they are just too weak.
Old Nov 6, 2007 | 08:44 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Can't a pull up resistor be used to sort the weak signal?
Old Nov 6, 2007 | 08:53 AM
Ryan's Avatar
Ryan
thats what i was thinking martin, as Stack suggest it in there manual, using a pull resistor. unsure on the ohm rating though.
Old Nov 6, 2007 | 09:31 AM
Stu @ M Developments's Avatar
PassionFords Creator
But only for some Tachs...
90% of the drivers we sell work the tachs perfectly fine with the suggested modification. The biggest problem are the early tachs such as these 3door ones as we havent had a set to work out how to modify them to accept a lower signal.
I am informed that the diode circuit above will work fine on the 3door tach, but i have yet to try it myself, although i did try it on an escos and it wouldnt work. Worth a try for the cost of the components.
Alternative remedies.
Use an Autometer tach signal doubler.
Fit an aftermarket counter.
Send clocks to a place who modify Tachs to wasted spark config.
Old Nov 6, 2007 | 09:35 AM
Chip's Avatar
Chip
Sorry Stu, think ive misunderstood slightly here.
So if I disconnect the "rpm output" wire on the ecu, and just take a feed off both tachos with a couple of diodes then my rev counter will work anyway as they generate the relevent spikes required by the dodgy ford tacho?
Old Nov 6, 2007 | 09:36 AM
Chip's Avatar
Chip
PS
Weird thing is with mine, it worked initially, then stopped!
Old Nov 6, 2007 | 09:43 AM
Apparently so mate... give it a try.
Your Ford tacho is watching the coil field, and the 2 amp wires are of course still connected to a coil each.
The voltage there is the same as it was on a std coil.
Old Nov 6, 2007 | 09:49 AM
Chip's Avatar
Chip
Makes perfect sense
I'll do that then, cool.
JJ will be pleased too, as that should fix his as well then.
I thought from the fact you had bothered to develop a seperate output that the coilpacks must spike less or something like that, but obviously it was just to make it as easy as possible for people to fit?
Old Nov 6, 2007 | 10:13 AM
Well, we didnt, Simon did, and he assured me that the zener diode circuit wont work. And, when i tried it, it doesnt.
However, i have heard of it being used successfully, so please let me know how you get on pal.
Old Nov 6, 2007 | 10:20 AM
RS500/364's Avatar
RS500/364
Makes perfect sense
So will i if if does you could try it on my RS500 i got a spare clock but the ECU is in romford
Old Nov 6, 2007 | 10:21 AM
Ryan's Avatar
Ryan
stu, i've tried it on 3dr clocks and it works, escort it doesnt for some reason, as we tried it on kev's a couple of years ago.
Old Nov 6, 2007 | 10:25 AM
Excelent news pal.
How bizzare. And to be fair to Simon, he did develop it on an Escort.
Old Nov 6, 2007 | 10:28 AM
Ryan's Avatar
Ryan
might just have been kev's car then, and we all know that car has a mind of its own
Old Nov 6, 2007 | 10:40 AM
Chip's Avatar
Chip
From what Stu is saying, it was Simon's too mate, and potentially all escos's therefore
Old Nov 6, 2007 | 10:45 AM
Ryan's Avatar
Ryan
chip, i think from what stu has said, simon developed the secs product on an escort, so an escort rev counter.
or maybe i've read it wrong?
Old Nov 6, 2007 | 10:47 AM
Chip's Avatar
Chip
Ryan, what is "it", do you mean the diode system detailed here that we are discussing, or are you chatting about something else?
Old Nov 6, 2007 | 10:53 AM
Ryan's Avatar
Ryan
no the diode system above.
been around for a while, as said i tried it about 2 yrs ago, when simon 1st released the s8.
Old Nov 6, 2007 | 11:14 AM
Chip's Avatar
Chip
Its that diode system that did NOT work on simon's car either from what Stu is saying, and thats why he said "to be fair to simon he did try in on an escort"
Old Nov 6, 2007 | 01:13 PM
Ryan's Avatar
Ryan
yeah sorry chip, reading further up the thread your right
Old Nov 6, 2007 | 05:33 PM
Matt Baxter
Back in black!
Could I fit a tacho from another car like a escort/mondeo that already uses a coilpack?
Old Nov 6, 2007 | 06:49 PM
Ryan's Avatar
Ryan
yes you could do but the dial wouldnt match.
Old Nov 6, 2007 | 06:50 PM
Matt Baxter
Back in black!
where do i need to fit them at the coil pack?
ps i dont have a clue when it comes to this sort of thing
Old Nov 6, 2007 | 06:52 PM
Ryan's Avatar
Ryan
yes off pin 1 & 3 of the coilpack plug, or off Pin 1 on both the ignition amps, whichever is either, and neither are
Old Nov 6, 2007 | 07:46 PM
Rs-Simon's Avatar
Rs-Simon
What colour is the wire at the rev counter end ?
Old Nov 6, 2007 | 07:48 PM
Ryan's Avatar
Ryan
green
Old Nov 6, 2007 | 09:29 PM
Matt Baxter
Back in black!
Cheers Ryan
Simon does that all make sense to you?
Old Nov 6, 2007 | 09:36 PM
Matt Baxter
Back in black!
green
dont have a green at the tacho
Old Nov 6, 2007 | 09:51 PM
kjc300's Avatar
kjc300
green
No you muppet!!!!
there'll be a green at the multiplug!!
Old Nov 6, 2007 | 10:05 PM
Rs-Simon's Avatar
Rs-Simon
I take it that pin 2 is green then.
Old Nov 6, 2007 | 10:07 PM
Matt Baxter
Back in black!
[quote="kjc300
No you muppet!!!!
there'll be a green at the multiplug!! [/quote]
Oi bit less of the muppet
I did say i know fuck all about this side of the car
I take its multiplug at the back of the clocks?
Old Nov 6, 2007 | 10:15 PM
Rs-Simon's Avatar
Rs-Simon
the green wire is on the back of the tacho plug
Old Nov 6, 2007 | 10:16 PM
Rs-Simon's Avatar
Rs-Simon
I hope
