rev counter for coil pack UP DATE ITS SORTED
Old Nov 6, 2007 | 10:17 PM
  #41
Jay,'s Avatar
Jay,
Sponsor
yes matt it feeds from the main ecu power conector up to the clock plug
Old Nov 6, 2007 | 10:33 PM
  #42
kjc300's Avatar
kjc300
to try this you need to make the the little resistor y-piece up first.
Then on the coilpack plug, connect the 2 wires up, one to each of the OUTSIDE wires (not the middle one!!). Then snip / disconnect the green wire from the ecu to the clocks and join the single end to the clocks!!
However this never worked on mine!!
Old Nov 6, 2007 | 10:38 PM
  #43
Matt Baxter's Avatar
Matt Baxter
Back in black!
nice one cheers
looks like another trip maplins tomorow then
if this does not work i will get a tacho from a mondeo or something like that and make it fit
Old Nov 6, 2007 | 10:44 PM
  #44
kjc300's Avatar
kjc300
does a 1.8 cvh sierra have a coilpack??
Old Nov 6, 2007 | 10:46 PM
  #45
Matt Baxter
Back in black!
dont think so but i will have a look tomorow at breakers yard
Old Nov 6, 2007 | 10:52 PM
  #46
Chip's Avatar
Chip
*** Sierra RS Custard ***
The green wire that went to your original coil is the one that you need to connect it too (but only the half that goes on to the rev counter not the wiring going back to the ecu)
Old Nov 6, 2007 | 10:57 PM
  #47
Matt Baxter
Back in black!
nice one cheers Chip
Old Nov 7, 2007 | 09:03 AM
  #48
Matt Baxter
Back in black!
well that didnt work
Old Nov 7, 2007 | 02:12 PM
  #49
Matt Baxter
Back in black!
Update
Went to the scrappys today and got another set of clocks and it works sort of
Its fine up to about 4k and then it fucks about
Old Nov 7, 2007 | 02:21 PM
  #50
kjc300's Avatar
kjc300
what clocks did you get then??
Old Nov 7, 2007 | 04:17 PM
  #51
Matt Baxter
Back in black!
a set from a late sierra twin cam
i did the mod as per the msd instructions.
but still did not work i then went to maplins and got the diodes and fitted
them to pin 1 and 3 on the coil packand then off to the green wire on the multi plug at the
back of the clocks and now the rev counter works fine until 3.5k and then it drops down to 0
i think i will just have to get an after market rev counter
Old Nov 7, 2007 | 04:20 PM
  #52
Jay,'s Avatar
Jay,
Sponsor
be a lot less bother than a hover
Old Nov 7, 2007 | 04:23 PM
  #53
kjc300's Avatar
kjc300
I know that................................
You've just been round here!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 7, 2007 | 06:04 PM
  #54
Matt Baxter
Back in black!
Yeah yeah
Old Nov 20, 2007 | 05:05 PM
  #55
Matt Baxter
Back in black!
fitted a mondeo rev counter and it works
cheers for all the help/advice lads
Old Nov 20, 2007 | 05:09 PM
  #56
Stu @ M Developments's Avatar
PassionFords Creator
Nice Job!
Old Nov 20, 2007 | 05:13 PM
  #57
Matt Baxter
Back in black!
it will do for now and it was only £10 so alot less than stack etc
just got to get another cossy speedo now as i had white dials before
Old Nov 20, 2007 | 09:04 PM
  #58
jason 3dr's Avatar
jason 3dr
used this all last year worked fine cost less than £2Name:  Tach_circuit.jpg
Old Sep 28, 2008 | 03:54 PM
  #59
scoooby slayer's Avatar
scoooby slayer
does that mondeo clock work without any other mods ?
Old Dec 30, 2008 | 08:19 PM
  #60
Gary Osborne's Avatar
Gary Osborne
up as i would like to know this too
Old Dec 30, 2008 | 08:33 PM
  #61
KSA-Cossie's Avatar
KSA-Cossie
And me,i've got the diode kit from MSD but car is tucked away till spring .
Old Jan 18, 2009 | 06:55 PM
  #62
mark_24v_wiring's Avatar
mark_24v_wiring
Matt,
Looking at doing this for me brother so he can actually get a reading up to his rev limit now what wire goes to what and is there anything needed to actually make the mondeo rev counter fit into the sierra housing?
Ta
Old Jan 19, 2009 | 06:34 AM
  #63
Matt Baxter
Back in black!
I used this, got the bits from maplins
As for the wiring as you look at the back of the mondeo tacho you have 3 pins top, middle and bottom
The top pin on the tacho goes to the left pin on the ribbon cable
middle pin(the one with white tape on it) goes to the middle pin on the ribbon cable
and the bottom pin on the tacho goes to the right pin on the ribbon cable
hope that all makes sense
Old Jan 19, 2009 | 06:42 AM
  #64
mark_24v_wiring
so you used the diode's and the mondeo counter to make it work properly?
Old Jan 19, 2009 | 07:33 AM
  #65
I used a £30 tacho driver and it works perfect, with coilpack.
Old Jan 19, 2009 | 07:37 AM
  #66
mark_24v_wiring
Its not a case of the rev counter not working for my brothers car its more a case of getting a reading upto the rev limit which is now 7600 i think, the mondeo counter fit seams like a good direction to go
Old Jan 19, 2009 | 03:22 PM
  #67
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Thanks for the detailed answer Matt
Steve.
Old Jan 19, 2009 | 04:42 PM
  #68
Matt Baxter
Back in black!
yeah mate you got it
Steve.
no probs mate (just hoope it makes sense)
Old Jan 19, 2009 | 04:49 PM
  #69
mark_24v_wiring
Does to me and as ill be fitting it to steve's car thats all that matters lol
Old Nov 24, 2011 | 03:32 PM
  #70
Fearless_Si's Avatar
Fearless_Si
Hi, Just wondering if the diode wiring will work on my car?
I have a Mk 4 escort fitted with a coil pack and a rev counter with the green (signal) wire.
Cheers.
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
IainRS1700T
Sep 25, 2015 06:44 AM
beller
Sep 21, 2015 04:13 AM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
