Car horns on a 3dr cossie
Got a bit of a problem with the car horns on our 3dr, instead of sounding like they should they are a bit dull sounding like they are covered up, ive checked them & there is nothing blocking them even tried another set but still the same, as anybody else had the same problem
They do knacker up after a while, go out of tune, some have a screw on them so you can retune.
Check the supply(volts) and earth and if ok then it is the horns, I fitted two NATILUS HORNS(from wilco) to my sapphy, bloody loud, one each side.
These are a twin air horn in a compact size, so now have twin air horns each side, thye are LOUD LOUD, about £20 each, you will just have to make up a simple wire extension for the earth that's all, twist the bracket in a vice through 90 degrees and they go straight on.
No probs matey, just trying to fit my DUKES of HAZARD horns on but so little room, made bracket to fit them under the n's inner wing same pposition but other side to washer bottle!!
Yeah bring back the 70's!!
Karl 3dr
102
14-10-2016 08:17 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
CabrioTurbo
01-08-2015 11:04 AM
