pinto cambelt
Old Apr 21, 2007 | 08:39 PM
bazpro's Avatar
bazpro
Default pinto cambelt
if the cam belt snap on a pinto is it true it doesnt actually damage anything inside? mine snapped today when it was idleing and got a new 1 to put on but dont know if i need 2 strip it down and have a look inside.
Old Apr 21, 2007 | 09:08 PM
gup's Avatar
gup
i dont thing they do fella i think they might snap the rockers tho if im right fit the new belt and keep turning the engine over by hand and c if it is catching anywhere
Old Apr 21, 2007 | 11:10 PM
djmillsy's Avatar
djmillsy
Fife Radge
they usually bend valves when they snap mate
Old Apr 21, 2007 | 11:34 PM
GVK.'s Avatar
GVK.
For the time it takes on a pinto, fit a belt and see what happens.
Old Apr 22, 2007 | 12:44 AM
As GVK, can almost guarantee no damage, especially as idling at the time.
I may be wrong but thought these were a "safe" engine anyway.
Worst count is ONE bent valve!!
Old Apr 22, 2007 | 01:00 AM
bazpro's Avatar
bazpro
yeah my dad was saying they are safe engines. he had 1 snap on a capri years ago and it was fine. will find out tommorrow if its damaged.
Old Apr 22, 2007 | 09:13 AM
gup's Avatar
gup
theses are safe fella my dads sierra 2.0 went on a hill fella and
we put a belt on it and it started first time
Old Apr 22, 2007 | 06:38 PM
bazpro's Avatar
bazpro
i put new belt on and it fired first time but only seemed 2 b on 3 cylinders so turned it off cleaned all the plugs and now it wont start. does this sound like a bent valve and if so would it b expensive 2 fix. seemed strange how it started first time though
Old Apr 22, 2007 | 07:43 PM
gup's Avatar
gup
have you put the leads in the right order
whip the rocker cover off and c if the rockers are broke if it the engine im thinking about
Old Apr 23, 2007 | 06:03 AM
Check again that belt is right, then if it is do a compy test as this is quickest way to see if there is a bent valve problem, I would be very suprised though, I have only ever seen one on a pinto due to belt snap, but that was at 8,700rpm, on a race car.
Old Apr 23, 2007 | 03:43 PM
JesseT's Avatar
JesseT
Depends on the type of Pinto engine, some can get damaged, some not. Think all the 2.0 had the potential to get damaged.
Old Apr 23, 2007 | 04:51 PM
Dave Parker's Avatar
Dave Parker
ive done a lot of these and have never seen any damage,capri cortina transit mk 2 rs. check tooth alignment again esp. on aux shaft its easy to be a tooth out
Old Apr 23, 2007 | 06:12 PM
bazpro's Avatar
bazpro
think its ignition timing going back up garage to have a check.
Old Apr 25, 2007 | 12:00 PM
davidreader5's Avatar
davidreader5
Hi All,
Yes information i have is if 1.6, it is interference engine and you will likely
have at least valve damage,
But if 2.0, is free wheeling engine and not likely to have damage, but do a precautionary compression test,
Regards Dave R.
chowfornow
14
Jan 5, 2019 09:01 PM
Chas
Oct 5, 2015 07:13 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
steff19
Escort Range
Sep 9, 2015 10:14 PM
