Manually turning engine over
Old Jan 19, 2007 | 06:18 PM
ram's Avatar
ram
Has a large member
Default Manually turning engine over
just changed my cambelt today, once it was al timed and tensioned up i turned the engine over slowley 3 times manually via the pully to check everything was good. it wasnt till after the 3 turns that i remembered i hadnt yet put oil in the engine yet! has this now damged my block?
when i had the head off off a few weeks back there was still a thin film of oil on the walls, has this been enough to protect?
cheers in advance.
Old Jan 19, 2007 | 06:36 PM
antony215's Avatar
antony215
Escort Rs Turbo
Should be fine if you didn't start it
Old Jan 19, 2007 | 06:46 PM
nick series1's Avatar
nick series1
I think you'll be fine.
Old Jan 19, 2007 | 10:17 PM
lukes1's Avatar
lukes1
Default no worries
no worries brother, we had a plank at work who drove a bmw 320 out the workshop before he realised! rattled like fook!
ram's Avatar
ram
Has a large member
cheers guys! had been worrying bout it all evening!
Old Jan 19, 2007 | 10:26 PM
rapidcossie's Avatar
rapidcossie
no load or friction on the engine so will be ok
Old Jan 20, 2007 | 04:05 PM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
you could turn it over BY HAND loads of time with no problem as long as you didnt start it.
Old Jan 24, 2007 | 01:56 AM
ram's Avatar
ram
Has a large member
cheers guys. started up alittle tappy which it never has before but i guess thats because it had new oil in it to get around
Old Jan 24, 2007 | 11:18 AM
davidnormanuk's Avatar
davidnormanuk
When you put new oil in did you prime the system before starting?
Old Jan 24, 2007 | 02:44 PM
ram's Avatar
ram
Has a large member
once i put oil in i turned the engine over another few times by hand.
then disconected the fuel pump and turned the engine over via the key for a total of 20seconds.
then plugged the fuel pump lead bk in and started car.
was there something else i should have done?
Old Jan 24, 2007 | 03:10 PM
davidnormanuk
As long as the oil pressure light went out in them 20 seconds you shouldn't have any problems. Just a bit worried about the tapping at start up.
Old Jan 24, 2007 | 04:52 PM
antony215's Avatar
antony215
Escort Rs Turbo
Depends on how long the engine was sat without any oil in you will get a bit of tapping untill the oil has got into the tappets.
Old Jan 24, 2007 | 04:55 PM
SafeChav's Avatar
SafeChav
Wouldn't worry about it in the slightest mate
Old Jan 24, 2007 | 05:34 PM
ram's Avatar
ram
Has a large member
cool the head had been sat dry on a stool in my garage since i took it off in the summer only just got it all back in and started up last weekend.
annoying thing is that i had to switch it off after half a minute cuz i realised i had a pin hole leak in the metal water pipe that goes to the turbo. so didnt get a chance to hear if the tapping would settle
off with the manifold again to replace the leaking pipe
Old Jan 24, 2007 | 06:22 PM
SafeChav's Avatar
SafeChav
If you want to run the engine before fixing that just keep the reservoir cap off and it shouldn't leak too bad as it wont pressurise the system.
Old Jan 24, 2007 | 07:22 PM
antony215's Avatar
antony215
Escort Rs Turbo
If it's been sat that long then just leave it to tick over and it should clear in 10-15 min's
The Underdog
29
Sep 7, 2015 09:49 PM
mick.slinn
Aug 10, 2015 01:38 PM
tankybaby66
Aug 9, 2015 07:13 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
