How bad ? cossie engine
Old Jan 6, 2007 | 06:39 PM
rabmc's Avatar
rabmc
Default How bad ? cossie engine
Right got a bit of a problem to say the least , but how bad i dont know
Changed cam shaft oil seals and putting everything back together as in setting timing up etc, now timing i believe was ok BUT the plug connector to crank sensor was un plugged which through me off because wouldnt start ,plug is a bit dodgy actually , and set up rotor arm to the marker on the cap
Now redone timing after i put this sensor back on , and some how i used the wrong marker on crank pulley and i think you know where im going with this one
Engine wouldt turn over obviously as was as if it was jammed
Now upon realising this reset it all up corrctly this is when we noticed the wrong marker ! etc
Now started first time but sounds as if its runing on 3 cylinders
Now is it head off time , or something else
3dr cos
Old Jan 6, 2007 | 06:43 PM
rapidcossie's Avatar
rapidcossie
bent valves maybe Rab...
they are costly..head will need to come of and be checked by a PRO...i.e anyone thats not you
hope it aint to bad mate...
did you not lock everything in place?
Old Jan 6, 2007 | 06:51 PM
rabmc's Avatar
rabmc
Yes it was actually correct about 5 times tbh , but that stupid connector coming out threw me off so thats why i kept re-doing it , but on the last time after connected plug back in this is when i realised the marker was the wrong one
Again it fird up but didnt sound as nice as it usually does
My fault , makes it feel all the better
Whats the likely scenario , damage wise
Old Jan 6, 2007 | 06:56 PM
Tac's Avatar
Tac
Rab hope its not that bad bud
Old Jan 6, 2007 | 06:57 PM
rapidcossie
valve to piston contact mate...
might be ok but might not be...
do a leak down test to see how the valves are seating...
Old Jan 6, 2007 | 06:59 PM
rabmc's Avatar
rabmc
Will do
Better get the tools backout then
Bigger and better if anything needs changed
Me and my big mouth , was sayin last week how id like to get the engine apart to see what its like and get a fancy head Fook me never though id be doing it for real
Old Jan 6, 2007 | 07:05 PM
cos jon's Avatar
cos jon
I suppose you forgot to spin it over by hand with the plugs out before trying to start it ??
Old Jan 6, 2007 | 07:06 PM
rabmc's Avatar
rabmc
When ?
I didn`t do this anyway
Old Jan 6, 2007 | 07:20 PM
DENNIS's Avatar
DENNIS
Originally Posted by rabmc
When ?
its most likely you have bent a valve or 2, pull an injector plug off one at a time when its running and see what cyl makes no change ( the one that dose not change engine speed / note is the one to look into )
then you know what cyl to look at when the head is off !!
you should always turn the engine over by hand before starting to recheck the timing / check all is OK !!!
best of luck , we all make mistakes .....
Old Jan 6, 2007 | 07:23 PM
rabmc's Avatar
rabmc
Thanks dennis , will do this tomorrow .
Im slightly pi$$ed off because it was my fault , but there were some noises in there on start up in general that i wasn`t happy with so in a way its not the end of the world .
Its a fairly new car to me so can inspect the the rest on taking it to bits i suppose .
Heard norris motorport do good things to cyl heads so once its off iL prob give them a phone to get prices etc
One things for sure IL never make that mistake again
Old Jan 6, 2007 | 07:37 PM
PAZ's Avatar
PAZ
HI BUD JUST CHANGED ME HEAD GASKET ON ME 3 DOOR AND WHEN I STARTED MINE FOR THE FIRST TIME IT WAS MISSING ON ONE TURNS OUT KNOCKED PLUG LEAD OFF THE CAP JUST CHECK JUST IN CASE.IF ITS THE HEAD OFF ITS A PEACE OF PEE (2 HOURS AND THE HEAD IS OFF)DONT KNOW WHY PEOPLE MAKE SUCH A FUSS ABOUT IT .DONT WORRY IT CAN BE SORTED.IF YOU NEED ANY POINTERS LET ME KNOW
Old Jan 6, 2007 | 07:42 PM
rabmc's Avatar
rabmc
Thanks paz will do mate , i checked everything lol and eventually started to realise what i was dreading
Maybe iL go out tomorrow and it will all be ok doubt it though
Never took a head off before , take it you take the lot out turbo and manifold connected
Old Jan 6, 2007 | 08:01 PM
PAZ's Avatar
PAZ
HI MATE yeh leave the inlet and exhuast on more to grab hold of ,then you can srip it on the bench better.when you come to put it back on cut 2 of your old head bolts heads off and cut a v in the top for a flat ended screw driver so you can screw these into the block to locate the new gasket as the bloke has no locating dowels.make sure you clean the head bolt holes in block out off old oil
Old Jan 6, 2007 | 08:02 PM
rabmc's Avatar
rabmc
Noted :
Out of intrest what head gasket did you use
Old Jan 6, 2007 | 08:10 PM
PAZ's Avatar
PAZ
ford motorsport group a head set from woodford gararge 200 quid thats every thing inc head bolts vstem seals ect
Old Jan 6, 2007 | 08:38 PM
rapidcossie
Rab...
my advice is if your not confident then do not do it...
will end up costing more in the long run...
not knocking you mate as i wouldnt attempt it either..
thats what this site is bad for....people saying this is a piece of piss and thats is easy to do...
its obviously not....
will you be confivdent running big boost thru a head gasket fitted by yourself?
build it once and build it proper...best way
Old Jan 6, 2007 | 08:57 PM
PAZ's Avatar
PAZ
HI AT THE END OF THE DAY JUST BECAUSE ITS A COZZY PEOPLE THINK THEY CANT DO IT AND END UP PAYING ŁŁŁŁŁŁŁŁŁŁŁŁŁ ITS A PINTO WITH A FANNCY HEAD,OF CAUSE YA HAVE TO A BIT HANDY WITH THE SPANNERS BUT TAKE YA TIME AND YA CAN.
Old Jan 6, 2007 | 09:02 PM
rapidcossie
i know the basics of any engine are fairly simple..
i would class myself as handy with spanners but have never done any major work on my car.
i have no doubt if i had the time, tools and ramps etc that i could buld myself an engine but would rather pay an expert i trust to build an engine that i can rely on...
cossies give me enough slepless nites as it is
Old Jan 6, 2007 | 10:09 PM
rabmc's Avatar
rabmc
Yeah mate , not that handy with the spanners , again iL be able to take it apart id aimagine
Again iL be in the street doing it west coast style lol so dont really have the facilitys ither
Old Jan 6, 2007 | 10:12 PM
rapidcossie
maybe get yourself a garage or something atleast?
do it under cover and take your time!
Old Jan 6, 2007 | 10:45 PM
rabmc's Avatar
rabmc
I know mate , would love a garage but again live in the middle house so doubt it at the moment
Head off and into the garden hut lol for inspection
A few beers and a candle
Old Jan 7, 2007 | 10:24 AM
Stoo's Avatar
Stoo
If you can get it down here you can use my garage Rab! My old escort can take a bit of wind and rain for the boys!
Old Jan 7, 2007 | 11:37 AM
rabmc's Avatar
rabmc
Cheers stoo appreciated
Im looking into getting a garage just round the corner from my house for a few months anyway , so hopefuly iL mange to get one and get the work done a bit quicker
Billy_RS
16
Oct 11, 2025 09:41 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
