HAVING TROUBLE WITH DOWNPIPE BOLTS
Old Dec 28, 2006 | 11:00 PM
khanny's Avatar
khanny
Default HAVING TROUBLE WITH DOWNPIPE BOLTS
Im trying to change the turbo on my erst and the downpipe bolts are proper seized on ive used loads of wd but now rounded the of any1 any ideas how i can get them off cheers, oh i dont have accsess to air tools so thats ruled out
Old Dec 28, 2006 | 11:33 PM
davecosworth's Avatar
davecosworth
IM BACK
cut them off and then redrill and tap the exhaust housing if re using it .
Old Dec 28, 2006 | 11:40 PM
khanny's Avatar
khanny
ITS A BIT ARCWAUDE TO GET ANYTHING IN THERE THO M8
Old Dec 28, 2006 | 11:47 PM
khanny's Avatar
khanny
ANY IDEAS IF THE TURBO CAN BE LIFTED OUT WITH THE DOWNPIPE ATTATCHED CHEERS
Old Dec 28, 2006 | 11:58 PM
antony215's Avatar
antony215
Escort Rs Turbo
If you've rounded them off beat a smaller socket on with a hammer
Old Dec 29, 2006 | 12:00 AM
davecosworth
IM BACK
drill the ends off the bolts then mate center punch the holes and the drill a small hole and work your way up to a 8mm drill bit might have to take the starter motor out first tho and dusconnect the battery first. you could beat a smaller socket over it but if they are that tight i doubt it will help matters
Old Dec 29, 2006 | 12:04 AM
khanny's Avatar
khanny
CHEERS GUYS IL GIVE IT A GO TOMMOZ
Old Dec 31, 2006 | 01:17 PM
SafeChav's Avatar
SafeChav
Try unbolting the elbow. May make your life a bit easier.
Those nuts/studs are common to snap though all the spare elbows i have the studs are snapped. Best drilled out and replaced with stainless bolts, won't snap again
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
