xr2i nightmare please help
Old May 10, 2006 | 01:12 PM
fiestaxr2i's Avatar
fiestaxr2i
Default xr2i nightmare please help
hi all as you may or may not know ive been having problems getting my xr2i too run and im rapidly loosing faith im tempted to scrap
the car will not spark ive done voltage and resistant checks on the ignition coil , crank position sensor , edis4 and ht leads and their all fine ive also bought new sparkplugs (motorcraft) and it still wont spark it just cranks over and over and theirs no spark at all
has any one got any ideas ?
could it be the Ecu although everything else is working
Old May 10, 2006 | 11:18 PM
xr-stu's Avatar
xr-stu
sounds stupid i know but have you checked all the fuses?
are the dash lights coming on when you turn the key?
if you look in the enginebay part of the engine loom will clip into the car loom, the plug with have 7 wires (iirc) going through it, disconnect the plug and check that the red wire is live, also check the black and the black/green wire are live when you put the ignition on.
sounds like a power feed problem, ie fuse etc. either than or the ecus wankered. check the above though.
Old May 11, 2006 | 05:19 AM
fiestaxr2i's Avatar
fiestaxr2i
thanks for the responce
all fuses are fine
all lights come on everthing works fine apart from getting no spark
and ill check wires 2nite cheers
Kyle Langford
27
Aug 5, 2019 07:54 PM
Andypandy260
Sep 23, 2015 10:28 PM
pabloXR
Sep 21, 2015 12:42 PM
JamesH
Sep 2, 2015 10:02 AM
lil rst boi
Aug 17, 2004 03:41 PM
