trouble cold starting with a back fire
Old Mar 12, 2006 | 09:41 AM
Dave Henshall's Avatar
Dave Henshall
Default trouble cold starting with a back fire
when the car has been stood over night or durin the day, it doesnt start first time, this has come more and more over the last few months (head gaskets aside) the fuel pump primes and the ISCV clicks, then i go to crank and teh rev coubnter needle boigs up wildly as the car cranks...
it wont fire though, ot i mean it does fire but not enought to actually get it running, as you let off the key, it half runs for a moment but not with enough umph to actually run.
i try again, and this time there is a loud bang and a backfire from the back, again, not running.
3rd time, i crank it fires and runs smoothly , even then restarting once its initally run, it starts ok.
what should i be checking for... last time the bang, flames and backfires were the crank sensor - ive re checked this and made sure the connectors are clean, all ok. when else can cause the boingy needle...? ive converted to coilpack aswell btw and the multiplugs under the bonnet have been donw away with by soldering them together and heat shrinking each cable individually.
Old Mar 12, 2006 | 12:42 PM
DazC's Avatar
DazC
Phase sensor? It's the only other rotational sensor for the engine. Jumping rev counter would indicate that the spark is being fired ramdomly...
Old Mar 12, 2006 | 04:30 PM
markk's Avatar
markk
fusebox ?
Old Mar 14, 2006 | 08:30 AM
Dave Henshall
its had brandnew fusebox , phase and tdc sensors.....
although this morning it didnt do it and started first time no probs
Old Mar 20, 2006 | 10:35 AM
Dave Henshall
only 3 degrees thismorning, and a band after it cranked the first time.
fitting a brand new bosch silver battery 2nite - see if its any better 2morrow. the halfords one that is one if you check the voltage in the morning it floating at 12.2 volts.... not enough me thinks...
Old Mar 20, 2006 | 11:17 AM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Cheked the coilpack? and the wiring/sensors associated with it? as that'd be my 1st port of call
Dan
Old Mar 20, 2006 | 01:34 PM
Dave Henshall
it all looks ok, and its a brand new coilpack and wiring - once warm it is ok....
Old Mar 21, 2006 | 01:58 PM
Dave Henshall
since new battery has been fitted, it now looks ok, a whole volt happiers on teh gauage in all conditions now, the old battery must have had a dud cell
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
The Enigma
13
Aug 20, 2015 09:38 PM
ekjim
Aug 17, 2015 08:57 PM
Archiejay
Aug 12, 2015 12:07 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
