excessive front tyre wear- cause?
Old Jul 23, 2004 | 02:18 PM
Firestarter's Avatar
Firestarter
Default excessive front tyre wear- cause?
Escort Cosworth, standard suspension setup, lowered 25mm, brand new tyres all round 1200miles ago, now the fronts are almost bald inside!!
Any ideas?
Old Jul 23, 2004 | 02:19 PM
mattysxguy's Avatar
mattysxguy
trackings out
Old Jul 23, 2004 | 03:02 PM
Dave Henshall's Avatar
Dave Henshall
tracking should be 0 deg , ie running parrallel and in line with the backs. when you lower it though, it will ajust this and will need re tracking.
Old Jul 26, 2004 | 09:06 PM
SmokeStoner's Avatar
SmokeStoner
tracking may be out, but more than likely be the fact that you have lowered the car 25mm, as this will give you more negative camber, which is ideal for cornering but a pain in the arse for tyre wear cause it will make the top of the wheel sit further in, which means it is wearing more on the inside edge, hence the baldness mate , ask for it to be tracked up again to check the front camber angles, plus your front toe angles aswell.
You can remedy this problem if you want by speaking to someone like Zoo Motorsport, as they can supply you with eccentric top mounts or adjustable lower arms, which would allow you to set it up the camber angles properly, although they could possibly advise you on a cheaper option as the other gear is quite expensive mate.
Give them a bell, and see what they say mate!!!
Old Jul 26, 2004 | 09:46 PM
Firestarter
cheers mate, good info, I noticed the camber after it was lowered.
Would have preffered it not to have been lowered, waiting for Castle Performance Engineering to get some std springs in to replace them as they fitted them in the first place................ fookin long wait, it's been about 8 months now!
Old Jul 27, 2004 | 01:30 AM
Billabong's Avatar
Billabong
Have you still got std Ford front bushes? New front poly bushes will make a big difference if so.
Old Jul 27, 2004 | 09:09 PM
Firestarter
mostly poly, I'll replace the lot & see what it's like, cheers Billabong.
Old Jul 28, 2004 | 11:14 PM
Billabong's Avatar
Billabong
Mine's slightly lowered, but I get far, far more than 1200miles out of the front's!! Poly front bushes & Koni's, and I had it all tracked up after fitting the suspension/bushes. Unfortunately, without something trick like the Zoo setup, some inside wear is likely (as per most Fords, lol) - to set the fronts up to combat this without anything 'trick' will give poorer turn in/handling, and what's the point in a performance car that drives like that ....
Might be worth giving Zoo a call, they have a fair bit of experience with suspension/handling set ups, could probably source you some springs to your needs too.
www.zoomotorsport.co.uk for contact details if needed, hope you sort it
Old Aug 3, 2004 | 08:24 PM
Firestarter
cheers mate, info much appreciated!
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
3drRich
Sep 13, 2015 07:32 PM
YODI
Aug 30, 2015 01:12 PM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
