fiesta wheels fitting????
Old Feb 4, 2006 | 06:24 PM
shreevy's Avatar
shreevy
Default fiesta wheels fitting????
i have just got mondeo rims for my xr2i 1.6 and have just placed them on my car they dont have tyres on them yet but if they did it looks like the will rub on the suspension.
has any 1 else found this problem how 2 fix do i need low profile tyres or do i need spacers
Old Feb 5, 2006 | 04:22 PM
cocaina_xr2i's Avatar
cocaina_xr2i
wrench it all
I had mondeo wheels in mine xr2i and the only rubing was in wheel arch so I took the grinder and you should know the rest but in the inside toward the suspension had no probs, what size tyres r u gonna use m8?
Old Feb 7, 2006 | 12:48 AM
snoozie76's Avatar
snoozie76
If where talking Si 16" 5 spokes, I believe there are two sizes of there, 6J and 6.5J, and ideally you want the 6J as its the thinner one.
And running 195/40/16 tyres to keep the rolling circumference roughly the same.
Shouldn't contact the outer arch. If there's slight rubbing on the spring seat you can rotate the shock 180 and gain a few mm clearance.
If we're talking different wheels, I may have wasted your time, soz!
Old Feb 7, 2006 | 09:29 AM
cocaina_xr2i
wrench it all
not at all mate thats truth what you said
Old Feb 8, 2006 | 05:49 PM
shreevy's Avatar
shreevy
hi yea it is the si 5 spokes,i have the tyres that came on them which are 205/50/16 cud i use the smaller 195/45/16 on these or wud they not fit
Old Feb 9, 2006 | 11:16 PM
snoozie76's Avatar
snoozie76
You'll get away with those tyres, I run them on mine - Toyo Proxes TS1's, which have a narrow sidewall giving a tad more space, believe Falken's are good also. But I reckon there's probably not a lot in it, tbh.
I'm on 40mm lowering springs (reckon its nearer 30 thou) and only get some slight rubs on the front arch liners, and a bit at the back when 4 up but rarely when there's two of us.
Got the steering rack centralised then tracked her up, it clears full lock on the 35mm wheel off-set (40mm wheel off-set plus 5mm spacers), so passes the MOT no problem.
Old Feb 11, 2006 | 04:33 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
go cheaper mate we use uniroyal rainsports 195 45 16 dont rub good grip good price
up to you
is it rubbing on shockey cup if so you may need upto 10 mm spacers and extended studs then poss sone arch grinding
tommy
JoeyBoyden
Jan 4, 2024 02:36 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
cossie4x4
Aug 14, 2015 06:29 PM
M K
Aug 12, 2015 06:57 PM
