Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
yb coilpack installation
Old May 28, 2005 | 04:20 PM
Dave Henshall's Avatar
Dave Henshall
Default yb coilpack installation
having just fitted my secs/msd coilpack conversion, thought id post some pics up, it is very simple to do, the hardest part of the job was getting the new sub loom through the bulkhead
basically you do as per stus instructions, i dont need to eloborate in them,
ill just show the pics as i did it.
Old May 28, 2005 | 04:37 PM
Dave Henshall
get rid of all the old stuff, chop the ends off and insulate them, re tape the loom so it looks factory.
i made a ally bracked to use the old coil mouting bolts.
coilpack in place
plug in the loom - you cant get it wrong...
run new ht leads
and tuck the connectors up out the way...
the hardest part was getting the new wires through the bulkead...
i pulled the water injectipn pipe through into the engine bay as far as i could, taped the new wires to it and then pulled it back into the car - hey presto they come through with it
push the wires into the empty sockets in the ECU connector. tape up loom and put ecu back up in its hidihole.
fire her up and away you go
finished.
not forgetting, god gave us hands, rs components gave us the skewdriver, the most usefull tool ive ever used for working on a car
Old May 28, 2005 | 04:47 PM
Graceland's Avatar
Graceland
Team HOTHOT!
excellant Dave - looking forward to fitting mine when the 2nd batch arrived
Old May 28, 2005 | 05:08 PM
Matt's Avatar
Matt
ditto that
good man
Old May 28, 2005 | 06:29 PM
Dave Henshall
nearly forgot....
you also need to chop off and solder together the wires going to the old coil/tacho surpressor here...
and tape that into the loom when you are tidying/chopping the rest of the old coil wiring otherwise the rev counter doesnt work properley
Old May 28, 2005 | 07:05 PM
Dave Henshall
so it really is getting tidier with all the old sh1te out of the way....
Old May 29, 2005 | 10:26 AM
alan rainbow's Avatar
alan rainbow
nice one dave have you re gaped plugs stu's doing my ecu next week
Old May 29, 2005 | 10:48 AM
Dave Henshall
yep, to 1mm, they are a funny tip i have to say..... ive gapped them as per pic...
using motorcraft 071C's from stu...
should the gap be 1mm as above , or 1mm vetically from the bottom of the tip to the top of the electrode...
Old May 29, 2005 | 10:57 AM
Graceland's Avatar
Graceland
Team HOTHOT!
the gap should be 1mm exactley as per the picture
and a lovely picture it is too
Old May 29, 2005 | 11:30 AM
Dave Henshall
i'm such an artist
Old May 29, 2005 | 02:34 PM
Stu @ M Developments's Avatar
PassionFords Creator
Well pleased you took the time to do that tutorial, nice work Dave
Old May 30, 2005 | 09:02 AM
alan rainbow
dave i allways fort that the filla gauge was placed flat ontop of the tip but could be wrong what boost pressure are you running
Old May 30, 2005 | 05:38 PM
Dave Henshall
alan,
i know what you mean like on a normal plug...
but the 071 tip doesnt actually come over the electrode, so the phisical gap is 1mm between the 2 edges. boost 1.5 bar, but ive got this missfire now that needs sorting
Old May 30, 2005 | 08:34 PM
alan rainbow
missfire is this since you fitted the coilpack
Old May 31, 2005 | 07:50 AM
Dave Henshall
no no no,, the missfire has been since i did the head gasket, but until now had put it down to the HT system as it was cruddy and had green mank on most of the connections, the coilacpk conversion has totally eliminated all that wiring that was suspect.
Old Jul 2, 2005 | 06:26 PM
Fiecos Dan's Avatar
Fiecos Dan
have you closed the gap.
i have to run 0.6mm on 57 plugs with the same coil pack, if i open it up it misses and cough's.
Old Jul 20, 2005 | 06:32 PM
Dave Henshall
err, champion c57 get some better plugs, they dont idle very well and dont last vary long, mine had them in when i first got it and it run like a bag of spanners
Old Sep 3, 2005 | 06:15 PM
Fiecos Dan's Avatar
Fiecos Dan
the 57's let me run a larger gap, compared to my ngk9's.
Old Jul 31, 2006 | 03:52 PM
costina's Avatar
costina
Live long and prosper!!
Dave, which pins on ecu one's 26 but the other is it 6 or 9????
cheers
Paul
Old Jul 31, 2006 | 04:01 PM
Dave Henshall
You will need a second cossie ignition amplifier.
You will only need 1 new wire from the ecu to under the bonnet. (ECU pin 26)
COIL 1 drives spark plugs 1 + 4
COIL 2 drives spark plugs 2 + 3
ORIGINAL AMPLIFIER
This list includes the original ignition wiring denoted by a *
Colours if shown may not be exact so refer using pin numbers.
* Pin 1: COIL 1 -(green) - Pin 1 on Coilpack
* Pin 2: EARTH - (Brown)
* Pin 3: SIGNAL GROUND - Pin 24 on ECU
* Pin 4: +12 volts ignition (BLACK/YELLOW)
* Pin 5: No connection
* Pin 6: INPUT - Pin 25 on ECU
* Pin 7: No connection
NEW IGNITION AMPLIFIER
# denotes wires can be connected to original amplifer plug above directly
Pin 1: COIL 2 - Pin 3 on Coilpack (Green\Red)
# Pin 2: EARTH
# Pin 3: SIGNAL GROUND - Pin 24 on ECU
# Pin 4: +12 volts ignition
Pin 6: Pin 26 on ECU
Additionaly, Coil pack centre pin (pin 2) connects to ignition +12v which
can be taken from Original ignition amplifier pin 4.
This will work on WEBER P8 and SECS S8 ecus with correct software/configuration.
Other ecu's will require extra drive board. (L1,L2,L6 and L8)
Old Jul 31, 2006 | 05:16 PM
costina's Avatar
costina
cheers Dave, i'm using L8 so i will need to get a board done by stu.
I have the loom and leads got them both at a show cheap
got a coil pack and extra amp
I'm thinking theres another wire to connect to ecu plug as my loom has two wires numbered 26 and 9 or 6 depending which way up.
Think the boards are in production now just waiting for dosh to do it
cheers
Paul
Old Jul 31, 2006 | 06:13 PM
Dave Henshall
YEP, 26 IS THE SECOND AMP TRIGER (THE LOOM DOES ALL THE REST OF THE WORK) AND THE 9 IS THE DRIVE FROM THE ECU TO DRIVE THE FACTORY REV COUNTER WHICH TAKES ITS TRIGGER FROM THE ORIGINAL COIL
Old Jul 31, 2006 | 10:35 PM
costina's Avatar
costina
Thanks
Old Dec 30, 2006 | 03:44 PM
trevCOSS's Avatar
trevCOSS
Originally Posted by Dave Henshall
nearly forgot....
which wires? Im stuck at this point but the pic is no longer there can anyone post me a pic so I know which wires to join?
Old Dec 31, 2006 | 10:37 AM
Dave Henshall
here you go - its the plastic bit that is screwed to the body near the coil, it has just 2 green wires to it... chop them off and join them together than tape them into the loom, the surpressor can then be unscrewed and put in a same place with your old coil and leads
whole pic set here...
http://smg.photobucket.com/albums/v125/apbms1/coilpack/
Old Dec 31, 2006 | 04:57 PM
trevCOSS's Avatar
trevCOSS
thankyou
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
