Magenta cossie resto, parts back on, deja vu!!
Old 19-04-2011, 02:03 PM
  #201
carlo
carlo's Avatar
Good result but ehh Just enjoy the car now
Old 19-04-2011, 03:44 PM
  #202
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Originally Posted by carlo
Nice one mate can you not just get msd just to trim the fuel map on the chip ?
We certainly can do yes, but be aware that many dyno's show a YB as too rich when air temps are high in teh dyno cell and the boost is artifically low due to lack of dyno load.
If you are certain that both temp and boost replicated real road conditions for your car there send us the chip with a note saying exactly what AFR you had with what boost and we can tweak it to suit.
Old 19-04-2011, 04:20 PM
  #203
coswurv
coswurv's Avatar
Ill have a look through the graphs etc and have a think, im happy with the chip Stu, i think its made good power for an "off the shelf chip" its drives nice, cold start is mint and the power delivery etc is quality well happy.
Old 19-04-2011, 05:06 PM
  #204
fezzajsy
fezzajsy's Avatar
nice one mate
Old 20-04-2011, 04:37 PM
  #205
JamesH
JamesH's Avatar
Nice one Paul, is it similar to what Cossie Rich made with same boost and inlet and no big inlet cam?
Old 20-04-2011, 05:44 PM
  #206
crumpet
crumpet's Avatar
this isnt even run in yet is it?
Old 20-04-2011, 06:04 PM
  #207
Staffi
Staffi's Avatar
Looks laggy Paul?? torque alittle low too mate??
BUT, atleast it's going....
Old 20-04-2011, 06:14 PM
  #208
bad boy rs
bad boy rs's Avatar
torque does seem dowm abit what boost is that at mate, fairplay for getting it all back together so quick
Old 20-04-2011, 06:29 PM
  #209
coswurv
coswurv's Avatar
It is a little laggy pete, also is down 12ft/lb on torque compared to the last turbo, is still a quick car when you drive it, im happy with it, its safe and im not number hunting so happy days. Sort the fueling so its slightly leaner if need be or maybe add some more boost and im sure the torque will come up a bit if i need to.
Old 20-04-2011, 06:31 PM
  #210
Staffi
Staffi's Avatar
Paul, my old saff had a graph similar tbh, 442bhp/360ft/lb BUTTTTTTTT, it drove alot better on the road than the grpah suggested and i'm guessing yours is similar??
Good on ya mate, glad you're pleased.....
Old 20-04-2011, 07:18 PM
  #211
coswurv
coswurv's Avatar
Yeah its a complete animal compared to what it was like before, the only issue is lag, its holding 2.1 bar of boost with a nice steady flat line nearly right up to the rev limiter, maybe the chip could do with a bit more ignition low down to help spool it up quicker if that would work? other than that i dont really know why the torque would drop, could it be exhaust housing as its only a .63 ? plus im only running standard ports,inlet,cams etc no inlet spacer
Old 20-04-2011, 07:44 PM
  #212
crumpet
crumpet's Avatar
Ab07 cam or bd14 inlet would make it drive better, more torque also
Old 20-04-2011, 07:57 PM
  #213
coswurv
coswurv's Avatar
Cheers, will a cam improve spool up aswell as torque ?
Old 20-04-2011, 09:24 PM
  #214
crumpet
crumpet's Avatar
aye, steve xr4i is the man to talk to, his YB made nearly 100ftlbs more torque on his t38 Iirc with just the ab07 alone!
Btw ab stands for ahmed bayjoo
Old 06-07-2011, 05:32 PM
  #215
coswurv
coswurv's Avatar
Well ive had a little play with the car the last few days, ordered some bist and pieces consisting of coilovers, amber indicators, hid kit, evo brembo calipers, focus rs discs .
Recieved the coilovers yesterday.
so this afternoon i set to fitting them, to be honest they were pretty easy to do. I set the ride height outside on some nice flat concrete and these are some pics of how it sits now,
a little pic of the ambers
So hopefully tomorrow will bring some calipers and discs for me, ill then have to make some bracket's to fit them and hopefully they'll clear my wheels ok.
Old 06-07-2011, 05:56 PM
  #216
Weeksy
Weeksy's Avatar
Looking good Paul.
Nice work on all aspects of the car my good man.
Nice coilovers dude!!!
Weeksy
Old 06-07-2011, 06:53 PM
  #217
NEIL A
NEIL A's Avatar
Good on you for sticking with it , looks nice with the ambers on.
When do you start to make boost on the GT30 ?
Old 06-07-2011, 07:28 PM
  #218
coswurv
coswurv's Avatar
Well after having the block and head machined for a multi layer gasket i also had the pistons machined to compensate for what was removed by me and also in the past and i went slightly to low which has made it a bit laggy, so i would say it starts around 3k maybe a bit less
Old 06-07-2011, 07:39 PM
  #219
NEIL A
NEIL A's Avatar
How low has it went im running 7.2:1 on the same turbo, just had the fueling checked today and need more fuel low down on the msd chip as it starts making boost at 1500 rpm.
Old 06-07-2011, 07:47 PM
  #220
coswurv
coswurv's Avatar
I honestly dont know mate, ive spoken to msd this week and they said they will map it for me and take the price of the chip i had from them off , After fitting the coilovers today and giving it some it seemed alot better, now its putting the power down instead of squatting its arse and bouncing around , Also maybe its partly me expecting it to pick up like my old t35 .55 used to. You can drive round the lag by just keeping the revs up as once its moving its alot better than pull away, i mean if you look at the dyno its just bogged down in fourth then held flat out so its gonna take time to spool up in those conditions i spose, im not saying thats how it should be just saying you can partly counteract it.
Old 06-07-2011, 08:49 PM
  #221
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
all in all a perfect saff imo paul
credit to your hard work mate !!
Old 06-07-2011, 09:24 PM
  #222
coswurv
coswurv's Avatar
Cheers Beef, can't wait to see yours all pained mate
Old 07-07-2011, 08:02 PM
  #223
coswurv
coswurv's Avatar
Well the postie came good again this afternoon with some nice evo brembo's and groovd focus rs discs, just got to fab some brackets and hope they clear my wheels
old discs size against new
old brakes
new brakes!
Pic doesnt really do the size of the calipers justice
BigErn, sorry chap these calipers came up in better condition so i couldnt really turn them down mate.
Old 07-07-2011, 10:30 PM
  #224
BigErn
BigErn's Avatar
No worries fella, saw you had some on the way so flogged em on the other day.
Should stop well with them on
Old 08-07-2011, 03:52 PM
  #225
carlo
carlo's Avatar
I had this brake set up on my saph they were brilliant im sure steve scott sells these kits he might have brackets on the shelf if you wanted to save a bit of time
Old 08-07-2011, 06:34 PM
  #226
coswurv
coswurv's Avatar
Ah they were easy to make bud,
Well today is set to making a template for the caliper brackets, once made i shot over to a friends machine shop and knocked these up,
After that it was a trip to raceparts for some bits and pieces to make the new front braided brake lines up. You have to grind some of the caliper to allow it to sit over your hub lugs so it sits nice and level otherwise it sits at an angle which i personnaly dont think looks as good.
A few randoms,
Gives you an idea on how big the brembos are!
To be honest its the first cossie or car even thats ever had a decent brake upgrade, i really wish i had done it sooner, stamp on these and your face comes off so christ knows what the ap kits must be like.
Old 08-07-2011, 06:56 PM
  #227
burnhamshaun
burnhamshaun's Avatar
So what do the brakes owe you all in as I wouldn't mind doing similar upgrade after coilovers
Old 08-07-2011, 07:22 PM
  #228
coswurv
coswurv's Avatar
Grooved focus rs discs £100
brembos with pads and pins etc £150
brackets (free as i made them myself)
braided lines £24 and made them also
So you can do this conversion for sub £300!
Old 08-07-2011, 07:27 PM
  #229
-beefy-
-beefy-'s Avatar
any pics of the brackets fitted paul ??
Old 08-07-2011, 07:31 PM
  #230
burnhamshaun
Plus the refurb they will prob need to get them looking like urs say £100+
Old 08-07-2011, 07:56 PM
  #231
coswurv
coswurv's Avatar
Just for you Beef, still need the edges rounding off and some new bolts, hub painting but it fits and works
Not always mate i picked these up complete for £150 as they are.
This might help out,
Txt is a bit small, basically it says on the left to remove that part of the caliper a bit at a time till it fits nice, then on the other side it says to grind down that web on both sides also to allow your bracket to sit nice and flat against the caliper.
Old 14-07-2011, 05:22 PM
  #232
coswurv
coswurv's Avatar
Right took the car out for a spin tonight and it started puffing a bit of blue on tickover when its hot, it may be nothing it may need valve guide seals, ive spent in excess of a grand on this car in the last week alone, with brand new gaz coilovers, new brakes, etc you can see by the resto on how good the car is, ive just had enough i hardly use it and when i do stuff like this happens so its the last straw for me, £5750 takes it away, NO PX'S or offers, its a bloody cheap car at that even with the puff of blue.
Old 14-07-2011, 09:06 PM
  #233
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Thats a shame you are giving up on it
What make of pads are you using in the front ?
Steve
Old 14-07-2011, 09:10 PM
  #234
Fil
ELASTIC BAND
Fil's Avatar
just see the for sale thread, which sent me here, top work, bugger about the blue smoke, but stick it in the garage for a week or 2 and take your mind off it. Come to your senses and dont let it go for peanuts!
As i read this is your 4th cosworth and its a keeper.
If I wernt trying to sell my house and move, i'd be on my way to Oxford in the morning with cash, before you changed your mind!
Old 15-07-2011, 04:33 PM
  #235
lee2cossies
lee2cossies's Avatar
Stunning work mate you cant give up now reapair it after coming this far. have you got a contact number for the brake pipes for the evo callipers? iv just fitted a set to mine and need some brake pipes now!
Old 15-07-2011, 04:40 PM
  #236
coswurv
coswurv's Avatar
I made my own, cost about £24 for the stuff.
Old 16-07-2011, 06:14 PM
  #237
coswurv
coswurv's Avatar
This has now been sheeted up and i will have a look at it over the winter, until then it can kiss my ass.
Old 16-07-2011, 06:23 PM
  #238
J98 FYA
J98 FYA's Avatar
lol it got the better of you.
Old 16-07-2011, 07:01 PM
  #239
BigErn
BigErn's Avatar
Good man, dont give up on it fella
Old 20-07-2011, 09:28 AM
  #240
JamesH
JamesH's Avatar
Good decision
Quick Reply: Magenta cossie resto, parts back on, deja vu!!
