moonstone 3dr small update
Old Apr 4, 2016 | 08:22 PM
  #1121
cozzy jeff's Avatar
cozzy jeff
yes mate,this starting issue seems to be down to lack of compression, apparently the oil pressure is holding the valves open,if you leave it 20 minutes till the pressure drops it'll fire up and run perfect.
I'm guessing an issue with the oil pump,Karl gonna check oil pressure tomorrow and discuss the next course of action.
Old Apr 4, 2016 | 08:34 PM
  #1122
RSMK4TURBO's Avatar
RSMK4TURBO
Hope all ok for you tomorrow, beautiful 3dr.
Old Apr 4, 2016 | 08:38 PM
  #1123
cozzy jeff's Avatar
cozzy jeff
me too mate,I'll update when I have more news.
Karl really knows his stuff so im sure he'll sort it.
Old Apr 5, 2016 | 03:36 PM
  #1124
cozzy jeff's Avatar
cozzy jeff
had Karl checking the car out today and he's discovered the oil pump is shagged, pump is producing 150 psi so looks like relief valve has jammed.
engine coming out tomorrow
Old Apr 5, 2016 | 04:28 PM
  #1125
costina's Avatar
costina
Live long and prosper!!
Fuck fuck fuck
Thats a lot of pressure guess it was a quite engine.
Old Apr 5, 2016 | 04:46 PM
  #1126
cozzy jeff's Avatar
cozzy jeff
dead quite lol.
I've been lucky really it could have jammed open given very little or no pressure then the damage would have been worse.hes gonna check the big ends while it's out,I'm not expecting any damage but they are the originals as far as I know so might aswell change them if there's any sign of wear.
Old Apr 5, 2016 | 04:53 PM
  #1127
costina's Avatar
costina
dead quite lol.
Well.fingers and toes crossed for ya mate as we all know how much time effort and money you have put into it.
Paul
Old Apr 5, 2016 | 05:12 PM
  #1128
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Shit not good! Still least it's in good hand
Old Apr 5, 2016 | 05:22 PM
  #1129
cozzy jeff's Avatar
cozzy jeff
I was a little concerned which pump he was gonna use as we've all heard the horror stories but he has genuine 2wd pumps in stock:top
Old Apr 5, 2016 | 05:25 PM
  #1130
Jay,'s Avatar
Jay,
Sponsor
Jesus Jeff after all that work ... still like you say at least it hasnt give up so the engine should be good
Regards Jay
Old Apr 5, 2016 | 05:40 PM
  #1131
cozzy jeff's Avatar
cozzy jeff
I'd be gutted if the engine let go,but then again I have a 1000mile old block sat here that's just been long studded with oil jets.
I'd just spent money on that instead, cars been off the road for six years and couple of months wouldn't hurt.
Old Apr 6, 2016 | 05:51 PM
  #1132
costina's Avatar
costina
So i don't really understand when its cold it starts with really high oil pressure. Yet when its hot with lower pressure it will not start..
Old Apr 6, 2016 | 07:04 PM
  #1133
cozzy jeff's Avatar
cozzy jeff
no mate,I think I've had two problems,a couple of weeks ago it woulnt start when hot,discovered the dizzy as slightly loose knocking the timing out,the the faulty oil pump was pumping up the followers holding the valves open obviously causing lack of compression.
once the pressure had dropped and closed it would fire,and of course when you're spinning it over your pumping fuel in fucking the plugs.
Old Apr 6, 2016 | 07:06 PM
  #1134
ajamesc's Avatar
ajamesc
Fooking nightmare! These things are sent to test us lol. Still don't let it dishearten you too much it will get fixed and your still have summer to enjoy all your hard work
Old Apr 6, 2016 | 07:17 PM
  #1135
cozzy jeff's Avatar
cozzy jeff
karl pulled the pump off today and he reckons its wreckedgood news is the oil filter done its job and karl found zero swarf in the engine.
new pump on:
karl asked if id like him to check the bearings,made sense while we were in there,very slight wear so a new set was installed
also noticed a lot of play in the wastgate so a 55 housing was banged on
Old Apr 6, 2016 | 07:23 PM
  #1136
costina's Avatar
costina
All good happy days.
Get and paint the block now lol.
Old Apr 6, 2016 | 07:37 PM
  #1137
cozzy jeff's Avatar
cozzy jeff
It's only money lol.
block looked great when I painted it years ago but it's turned to shit now.
engines back in and running,mapping starts tomorrow.
Old Apr 6, 2016 | 07:38 PM
  #1138
costina's Avatar
costina
What power you after.
Old Apr 6, 2016 | 07:41 PM
  #1139
cozzy jeff's Avatar
cozzy jeff
as much as possible without breaking it.
Karl doesn't have a rolling road so will have to take it elsewhere for a power run,probably msd
Old Apr 6, 2016 | 07:51 PM
  #1140
costina's Avatar
costina
What spec you running 55 housing for starts.
Old Apr 6, 2016 | 08:20 PM
  #1141
cozzy jeff's Avatar
cozzy jeff
55lb Siemens, rs500 inlet,100mm cooler,on l8 ecu with wasted spark.
I'm guessing 360 BHP?
Old Apr 6, 2016 | 08:25 PM
  #1142
costina's Avatar
costina
Be more than that mate.
Old Apr 6, 2016 | 08:39 PM
  #1143
cozzy jeff's Avatar
cozzy jeff
be nice,what's your guess?
Old Apr 6, 2016 | 08:57 PM
  #1144
costina's Avatar
costina
Difficult to say really can only go on what mine is. Should be over 380 on a 55 housing. Depends on what boost mine is flat out.
Old Apr 7, 2016 | 07:26 PM
  #1145
throttle jockey's Avatar
throttle jockey
Iwas with Karl today and basically the scored gear parts made swarf and that blocked a outlet witch then sent a 150 bar to the hydrolic lifters witch then pushes all the valves open leaving no compression at all but after a short while they return to normal loosing that pressure and cycle starts again reason for not starting was the lifters forced open by the way car looks mint well done nice one just thought I'd clear that up for you lol.....
Old Apr 7, 2016 | 07:41 PM
  #1146
cozzy jeff's Avatar
cozzy jeff
thanks for that,it probably needs a good wash now does it?
Old Apr 7, 2016 | 08:03 PM
  #1147
Staffi's Avatar
Staffi
Lol Jeff, more interested if it's dirty
Old Apr 7, 2016 | 08:14 PM
  #1148
cozzy jeff's Avatar
cozzy jeff
haha,I know the cars in good hands but I don't think he'll wash it before I pick it up .
not heard from Karl today so guess no news is good news?
Old Apr 7, 2016 | 08:29 PM
  #1149
throttle jockey
They were were working on it Jeff I didn't really ask about what was going on I was stripping sump off my own engine lol...(as they looked very busy)to see what it needed witch was nothing......but wanted Karl's reassurance it is right
Old Apr 7, 2016 | 08:36 PM
  #1150
cozzy jeff's Avatar
cozzy jeff
I'm glad he hasn't rang tbh because every time he does it cost me more money
Old Apr 8, 2016 | 07:28 AM
  #1151
throttle jockey
Lol..don't know what your engine spec is but my 3dr was same turbo as yours but on Karl's 500 spec motor and his map wow....it was a weapon very responsive I'm sure you will be very pleased I never rroaded mine but it held its own against 450bhp cars but didn't quite have legs to pull on them but for that turbo it was fast remember dyno figures are giudelines they don't mean much it's how a car performs on the Tarmac that proves the score
Old Apr 8, 2016 | 04:06 PM
  #1152
cozzy jeff's Avatar
cozzy jeff
sounds good to me,picking it up in the morning so looking forward to the trip home.
Old Apr 9, 2016 | 11:13 AM
  #1153
BRAMMER's Avatar
BRAMMER
Good and bad news but it's sorted and ready to kick it's fanny in, looking forward to Heaves pal
Old Apr 9, 2016 | 02:19 PM
  #1154
cozzy jeff's Avatar
cozzy jeff
cars home now mate,really happy with the power,the front end needs sorting as the steering feels a little loose,causes the car to drift slightly, I'll check it out tomorrow.
the front wheel arch kit has started to peel off with being sat in the sun so I've text the painter to have that sorted.
got my confidence back with the car so once the kit is sorted I'm good for heaves.
Old Apr 11, 2016 | 07:56 PM
  #1155
BRAMMER's Avatar
BRAMMER
Thats great news, you and Mike entering concours?
Old Apr 12, 2016 | 09:18 AM
  #1156
cozzy jeff's Avatar
cozzy jeff
Don't know about Mike but I might have a go at Croft, the front arches have started to peel from the wings so if spoke to the painter and he's gonna get me in in a week or two,tyres have caught the arches on the way up to harteside so he's sorting that aswell.
I'm going to buy some new side stripes and have him fit them aswell
got the "j" hooks to go on the front but want the bells anodised first.
then it might be ready for the show.
Old Apr 12, 2016 | 08:14 PM
  #1157
Cossy Mike's Avatar
Cossy Mike
I'll be doing Croft only probably, was a good day last year
Old Apr 12, 2016 | 09:41 PM
  #1158
JC600's Avatar
JC600
Just had a quick look through, this thread is awesome......top work, my favourite colour too.
Old Apr 13, 2016 | 08:04 PM
  #1159
At least you caught your engine at the right time.
Old Apr 16, 2016 | 09:19 AM
  #1160
BRAMMER's Avatar
BRAMMER
Sounds good Jeff, car deserves the moulding. Can't wait to see it again
